Particle Integrations with Ubidots
I have a problem with integrating Ubidots to Particle, I followed the tutorial but I can’t get it to work, I’m getting an error:
“error status 400 from industrial.api.ubidots.com”
Here is my integration example on Particle:
    "event": "ubidots",
    "url": "https://industrial.api.ubidots.com/api/v1.6/devices/{{{PARTICLE_DEVICE_ID}}}",
    "requestType": "POST",
    "noDefaults": false,
    "rejectUnauthorized": true,
    "headers": {
        "X-Auth-Token": "MY_TOKEN",
        "Content-Type": "application/json"
    "body": "{{{PARTICLE_EVENT_VALUE}}}"
and here is the sample of my Argon code:
long randNumber;
void setup()
  Particle.function("controlPnl", controlPnl);
  Particle.connect();
void loop()
int controlPnl(String command)
  if (command == "temperature")
    randNumber = random(90);
    Particle.publish("ubidots", String(randNumber), PRIVATE);
  return randNumber;
Please advise, thank you :stuck_out_tongue:
Okay, I found my mistake, payload had to be in JSON format so I got this to work with following code:
long randNumber;
void setup()
  Particle.connect();
void loop()
    // JSONWriter &beginArray();
    char buf[622];
    memset(buf, 0, sizeof(buf));
    JSONBufferWriter writer(buf, sizeof(buf) - 1);
    writer.beginObject();
    writer.name("temperature").value(randNumber);
    writer.endObject();
    Particle.publish("ubidots", String(buf), PRIVATE);
  return randNumber;
Hello @codev3rt
That’s correct, the Ubidots API expects a JSON, not a “raw” number and anything else.
I’d recommend taking a look at our library for Particle devices at
