Hello everyone! I am having issues subscribing to Ubidots events. I am trying to do this example: 5. Create Ubidots Webhook to Particle to Control Things .
Ubidots is registering the events when I toggle the digital switch however Particle is not receiving. Do you all have any suggestions?
I’ve replaced the Particle_Token text with a Two-Legged Auth (Server) token in both the “Active Trigger” & “Back To Normal” body fields.
Here is the Ubidot Event Config:
When I toggle the switch, it produces points on Ubidots event view:
Here is the code:
Here is the webhook config on Particle:
