Problem Connection PZEM00T to Ubidots
Hai, I have problem with this code:
  • Libraries included
#include <WiFi.h>
#include <WiFiMulti.h>
#include “soc/timer_group_struct.h”
#include “soc/timer_group_reg.h”
WiFiMulti WiFiMulti;
  • Libraries PZEM-004 Meter
    #include <PZEM004T.h> // https://github.com/olehs/PZEM004T
    PZEM004T pzem(&Serial2); // UART2 at pins IO-16 (RX2) and IO-17 (TX2)
    IPAddress ip(192,168,1,6);
  • Internal Temperature sensor in ESP32
    #ifdef __cplusplus
    extern “C” {
    #endif
    uint8_t temprature_sens_read();
    #ifdef __cplusplus
    #endif
  • Constants and objects
char const * SSID_NAME = “"; // Put here SSID name
char const * SSID_PASS = "
”; // Put here password
char* TOKEN = “**************”; // Put here your TOKEN
char* DEVICE_LABEL = “esp32-pzem”; //Device label
/* Put here your variable’s labels*/
char const * VARIABLE_LABEL_1 = “volts”;
char const * VARIABLE_LABEL_2 = “amperes”;
char const * VARIABLE_LABEL_3 = “power”;
char const * VARIABLE_LABEL_4 = “energy”;
char const * VARIABLE_LABEL_5 = “state_meter”;
char const * VARIABLE_LABEL_6 = “rssi”;
char const * VARIABLE_LABEL_7 = “temperature_internal”;
char const * VARIABLE_LABEL_8 = “scan_data”;
float v_prev,i_prev,p_prev,e_prev;
float v_now,i_now,p_now,e_now;
long state_meter, scan_connection;
/* HTTP Settings */
char const * HTTPSERVER = “industrial.api.ubidots.com”;
const int HTTPPORT = 80;
char const * USER_AGENT = “ESP32”;
char const * VERSION = “2.0”;
WiFiClient clientUbi;
  • Auxiliar Functions
void ReconnectDevices() {
while (true) {
  Serial.println("Connecting to PZEM...");
  if(pzem.setAddress(ip))
    break;
/* Connects to AP */
WiFiMulti.addAP(SSID_NAME, SSID_PASS);
while(WiFiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
    delay(100);
WiFi.setAutoReconnect(true);
Serial.println(F(“WiFi connected”));
Serial.println(F("IP address: "));
if (clientUbi.connect(HTTPSERVER, HTTPPORT)) {
Serial.println(“connected to Ubidots cloud”);
Serial.println(“could not connect to Ubidots cloud”);
void SendToUbidots(char* payload) {
int contentLength = strlen(payload);
/* Connecting the client */
clientUbi.connect(HTTPSERVER, HTTPPORT);
if (clientUbi.connected()) {
/* Builds the request POST - Please reference this link to know all the request’s structures https://ubidots.com/docs/api/ */
clientUbi.print(F(“POST /api/v1.6/devices/”));
clientUbi.print(DEVICE_LABEL);
clientUbi.print(F(" HTTP/1.1\r\n"));
clientUbi.print(F(“Host: “));
clientUbi.print(HTTPSERVER);
clientUbi.print(F(”\r\n”));
clientUbi.print(F(“User-Agent: “));
clientUbi.print(USER_AGENT);
clientUbi.print(F(”/”));
clientUbi.print(VERSION);
clientUbi.print(F("\r\n"));
clientUbi.print(F(“X-Auth-Token: “));
clientUbi.print(TOKEN);
clientUbi.print(F(“Connection: close\r\n”));
clientUbi.print(F(“Content-Type: application/json\r\n”));
clientUbi.print(F(“Content-Length: “));
clientUbi.print(contentLength);
clientUbi.print(F(”\r\n\r\n”));
clientUbi.print(payload);
Serial.println(F("Making request to Ubidots:\n"));
Serial.print("POST /api/v1.6/devices/");
Serial.print(DEVICE_LABEL);
Serial.print(" HTTP/1.1\r\n");
Serial.print("Host: ");
Serial.print(HTTPSERVER);
Serial.print("\r\n");
Serial.print("User-Agent: ");
Serial.print(USER_AGENT);
Serial.print("/");
Serial.print(VERSION);
Serial.print("X-Auth-Token: ");
Serial.print(TOKEN);
Serial.print("Connection: close\r\n");
Serial.print("Content-Type: application/json\r\n");
Serial.print("Content-Length: ");
Serial.print(contentLength);
Serial.print("\r\n\r\n");
Serial.print(payload);
Serial.println(“Connection Failed ubidots - Try Again”);
/* Reach timeout when the server is unavailable */
int timeout = 0;
while (!clientUbi.available() && timeout < 5000) {
timeout++;
delay(1);
if (timeout >= 5000) {
Serial.println(F(“Error, max timeout reached”));
break;
/* Reads the response from the server */
Serial.println(F("\nUbidots’ Server response:\n"));
while (clientUbi.available()) {
char c = clientUbi.read();
Serial.print(c); // Uncomment this line to visualize the response on the Serial Monitor
/* Disconnecting the client */
clientUbi.stop();
  • Main Functions
ReconnectDevices();
// disable watchdog for the other unused cpu
TIMERG0.wdt_wprotect = TIMG_WDT_WKEY_VALUE;
TIMERG0.wdt_feed = 1;
TIMERG0.wdt_wprotect = 0;
scan_connection++;
Serial.print(scan_connection);
char payload[200];
char str_val_1[30];
char str_val_2[30];
char str_val_3[30];
char str_val_4[30];
char str_val_5[30];
char str_val_6[30];
char str_val_7[30];
char str_val_8[30];
//char str_lat[30];
// char str_lng[30];
/* Read PowerMeter PZEM-004 or PZEM-004T*/
float v = pzem.voltage(ip);
if (v < 0.0) v = 0.0;
Serial.print(v);Serial.print("V; ");
float i = pzem.current(ip);
if(i >= 0.0){ Serial.print(i);Serial.print("A; "); }
float p = pzem.power(ip);
if(p >= 0.0){ Serial.print(p);Serial.print("W; "); }
float e = pzem.energy(ip);
if(e >= 0.0){ Serial.print(e);Serial.print("Wh; "); }
// float lat = 3.436161936071848;
// float lng = -76.51575728912671;
// Important: Avoid to send a very long char as it is very memory space costly, send small char arrays
/* RSSI ESP32 */
long rssi = WiFi.RSSI();
Serial.print(“RSSI; “);
Serial.print(rssi);
Serial.println(” rssi”);
/*  Internal Temperature ESP32 */
float internal_temperature = ((temprature_sens_read() - 32) / 1.8); /// Convert raw temperature in F to Celsius degrees
Serial.print("Temperature: ");
Serial.print(internal_temperature);
Serial.println("°C");
/---- Transforms the values of the sensors to char type -----/
/* 4 is mininum width, 2 is precision; float value is copied onto str_val*/
dtostrf(rssi, 4, 2, str_val_6); // rssi
dtostrf(internal_temperature, 4, 2, str_val_7); // internal_temperature
dtostrf(scan_connection, 4, 2, str_val_8); // scan send data ubidots
 /* -- Communication failure with meter -- */
  * If the ESP32 has no communication with the meter it will load the last values when connected.
if ((i == -1.00) && (p == -1.00) && (e == -1.00))
      /* Previous Measurements */
      state_meter=1;
      v_prev = v_now;
      i_prev = i_now;
      p_prev = p_now;
      e_prev = e_now;
      dtostrf(v_prev, 4, 2, str_val_1);    // Volts
      dtostrf(i_prev, 4, 2, str_val_2);   //  Amp
      dtostrf(p_prev, 4, 2, str_val_3);   //  W  -power
      dtostrf(e_prev, 4, 2, str_val_4);   //  Wh  -energy
      dtostrf(state_meter, 4, 2, str_val_5);   //  state_meter
}else
     /* Current Measurement */
      state_meter=0;
      v_now=v;
      i_now=i;
      p_now=p;
      e_now=e;
      dtostrf(v_now, 4, 2, str_val_1);           // Volts
      dtostrf(i_now, 4, 2, str_val_2);           //  Amp
      dtostrf(p_now, 4, 2, str_val_3);           //  W  -power
      dtostrf(e_now, 4, 2, str_val_4);           //  Wh  -energy
    sprintf(payload, "{\"");
    sprintf(payload, "%s%s\":%s",     payload, VARIABLE_LABEL_1, str_val_1);      // volts
    sprintf(payload, "%s,\"%s\":%s",  payload, VARIABLE_LABEL_2, str_val_2);      // amp
    sprintf(payload, "%s,\"%s\":%s",  payload, VARIABLE_LABEL_3, str_val_3);      // power
    sprintf(payload, "%s,\"%s\":%s ", payload, VARIABLE_LABEL_4, str_val_4);      // energy
    sprintf(payload, "%s,\"%s\":%s ", payload, VARIABLE_LABEL_5, str_val_5);      // state power meter
    sprintf(payload, "%s,\"%s\":%s ", payload, VARIABLE_LABEL_6, str_val_6);      // RSS1
    sprintf(payload, "%s,\"%s\":%s ", payload, VARIABLE_LABEL_7, str_val_7);      // internal_temperature
    sprintf(payload, "%s,\"%s\":%s ", payload, VARIABLE_LABEL_8, str_val_8);      // scan send data ubidots
/* Calls the Ubidots Function POST */
SendToUbidots(payload);
delay(10000);
// Check Wi-Fi connection every 5 min
// 300,000 ms = 5 minutes
// 300,000 ms /10000 ms = 30 scan
if(scan_connection>=30) {
ReconnectDevices();
scan_connection=0;
The Sensor can’t send the data. In sensor light 5vRx is on and the light blink, but it not transfer data to module and can’t transfer data to Ubidots platform…
Normaly Rx and Tx will blink and transfer the data…
