Problem to generate Dashboard from sum (x, M) synthetic variable
Hello I have a synthetic variable that works normal, and generates its values, but when I try to generate any Dashboard of it the graph appears in error and does not display anything.
The synthetic variable is simply the sum each month: sum (rain, “M”)
I can’t generate a graph of this synthetic variable item?
Can you help me please?
Hi @escardoso,
I hope all is well.
Yes, you should be able to create widgets with synthetic variables values. Can you please make sure to have selected on the dashboard a data range where the synthetic variable has values? otherwise you are going to see the message “No data found”. In case you still facing this issue after that, please advise your username, dashboard name and widget.
