I made the wifi switch with the code of a member of the community and it worked perfectly at first but today it no longer subscribes I have to reset the module so that it subscribes to the last value, in the same way it no longer responds with the google assistant
here the code
* Libraries
#include "UbidotsESPMQTT.h"
* Define constants
#define TOKEN "BBFF-AYoaftKUU5BdjJX8cCuegoESpDY47M" // Your Ubidots TOKEN
#define WIFINAME "FRANCO" //Your SSID
#define WIFIPASS "74958638" // Your Wifi Pass
#define DEVICE_LABEL "wifiswitch" // Name of the device
#define VARIABLE_LABEL1 "light" // Name of the Ubidots variable
const int ERROR_VALUE = 65535; // Error value
const uint8_t NUMBER_OF_VARIABLES = 2; // Cantidad de variables a las que el programa se va a suscribir
char * variable_labels[NUMBER_OF_VARIABLES] = {"light"}; // Variables names
#define luz 0
#define boton 2
int seguro=0;
int ledState = LOW; // the current state of the output pin
int buttonState; // the current reading from the input pin
int lastButtonState = HIGH; // the previous reading from the input pin
int reading;
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50;
float estadoluz; // Variable to be used in the code
float value; // Variable to store input data
uint8_t variable; // To use with the switch case
Ubidots ubiClient(TOKEN);
WiFiClient client;
* Auxiliar functions
char* variable_label = (char *) malloc(sizeof(char) * 30);
get_variable_label_topic(topic, variable_label);
value = btof(payload, length);
set_state(variable_label);
execute_cases();
free(variable_label);
/////////////////Light////////////////////
digitalWrite(luz, estadoluz);
// Parse topic to extract the variable label which changed value
void get_variable_label_topic(char * topic, char * variable_label) {
Serial.print("topic:");
Serial.println(topic);
sprintf(variable_label, "");
for (int i = 0; i < NUMBER_OF_VARIABLES; i++) {
char * result_lv = strstr(topic, variable_labels[i]);
if (result_lv != NULL) {
uint8_t len = strlen(result_lv);
char result[100];
uint8_t i = 0;
for (i = 0; i < len - 3; i++) {
result[i] = result_lv[i];
result[i] = '\0';
Serial.print("Label is: ");
Serial.println(result);
sprintf(variable_label, "%s", result);
break;
// cast from an array of chars to float value.
float btof(byte * payload, unsigned int length) {
char * demo = (char *) malloc(sizeof(char) * 10);
demo[i] = payload[i];
float value = atof(demo);
free(demo);
return value;
// State machine to use switch case
void set_state(char* variable_label) {
variable = 0;
for (uint8_t i = 0; i < NUMBER_OF_VARIABLES; i++) {
if (strcmp(variable_label, variable_labels[i]) == 0) {
break;
variable++;
if (variable >= NUMBER_OF_VARIABLES) variable = ERROR_VALUE; // Not valid
// Function with switch case to determine which variable changed and assigned the value accordingly to the code variable
void execute_cases() {
switch (variable) {
case 0:
estadoluz = value;
Serial.print("Luz: ");
Serial.println(estadoluz);
break;
case ERROR_VALUE:
Serial.println("error");
break;
default:
Serial.println("default");
Sets the broker properly for the business account
* Funcion principal
pinMode(luz, OUTPUT);
pinMode(boton, INPUT);
ubiClient.ubidotsSetBroker("industrial.ubidots.com"); // Sets the broker properly for the business account
ubiClient.setDebug(true); // Pass a true or false bool value to activate debug messages
ubiClient.wifiConnection(WIFINAME, WIFIPASS);
ubiClient.begin(callback);
if(!ubiClient.connected()){
ubiClient.reconnect();
char* deviceStatus = getUbidotsDevice(DEVICE_LABEL);
if (strcmp(deviceStatus, "404") == 0) {
ubiClient.add("light", 0); //Insert your variable Labels and the value to be sent
ubiClient.ubidotsPublish(DEVICE_LABEL);
ubiClient.loop();
ubiClient.ubidotsSubscribe(DEVICE_LABEL,VARIABLE_LABEL1); //Insert the Device and Variable's Labels
Serial.println(variable_labels[1]);
ubiClient.loop();
Read();
Debounce();
// save the reading. Next time through the loop, it'll be the lastButtonState:
lastButtonState = reading;
void Read(){
// read the state of the switch into a local variable:
reading = digitalRead(boton);
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
void Debounce(){
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
Toggle();
void Toggle(){
// only toggle the LED if the new button state is LOW
if (buttonState == LOW) {
ledState = !ledState;
// set the LED:
digitalWrite(luz, ledState);
ubiClient.add("light", ledState); //Insert your variable Labels and the value to be sent
char* getUbidotsDevice(char* deviceLabel) {
char* data = (char *) malloc(sizeof(char) * 700);
char* response = (char *) malloc(sizeof(char) * 400);
sprintf(data, "GET /api/v1.6/devices/%s/", deviceLabel);
sprintf(data, "%s HTTP/1.1\r\n", data);
sprintf(data, "%sHost: industrial.api.ubidots.com\r\nUser-Agent:wifiswitch/1.0\r\n", data);
sprintf(data, "%sX-Auth-Token: %s\r\nConnection: close\r\n\r\n", data, TOKEN);
char* data1 = data;
free(data);
if (client.connect("industrial.api.ubidots.com", 80)) {
client.println(data1);
else {
free(data);
return "e";
int timeout = 0;
while(!client.available() && timeout < 5000) {
timeout++;
if (timeout >= 4999){
free(data);
return "e";
delay(1);
int i = 0;
while (client.available()) {
response[i++] = (char)client.read();
if (i >= 399){
break;
char * pch;
char * statusCode;
int j = 0;
pch = strtok (response, " ");
while (pch != NULL) {
if (j == 1 ) {
statusCode = pch;
pch = strtok (NULL, " ");
j++;
free(response);
return statusCode;
