Problem with ecg sensor and esp32 code
The code below did not connect to the cloud. The code keeps failing. anybody should please help with the correct code or any corrections in the code?
#include <WiFi.h>
#include <PubSubClient.h>
#define WIFISSID “adextronics” // Put your WifiSSID here
#define PASSWORD “111111110” // Put your wifi password here
#define TOKEN “BBFF-fChAGEkTuGEeMgd07HWvYrIJgsFeeq” // Put your Ubidots’ TOKEN
#define MQTT_CLIENT_NAME “g59jy84usq” // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
#define VARIABLE_LABEL “sensor” // Assing the variable label
#define DEVICE_LABEL “esp32” // Assig the device label
#define SENSOR A0 // Set the A0 as SENSOR
char mqttBroker[] = “industrial.api.ubidots.com”;
char payload[100];
char topic[150];
char str_sensor[10];
WiFiClient ubidots;
PubSubClient client(ubidots);
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
Serial.println(topic);
void reconnect() {
while (!client.connected()) {
Serial.println(“Attempting MQTT connection…”);
// Attemp to connect
  Serial.println("Connected");
  Serial.print("Failed, rc=");
  Serial.print(client.state());
// Assign the pin as INPUT
pinMode(SENSOR, INPUT);
Serial.print(“Waiting for WiFi…”);
Serial.print(".");
delay(500);
Serial.println("");
Serial.println(“WiFi Connected”);
client.setCallback(callback);
if (!client.connected()) {
reconnect();
sprintf(topic, “%s%s”, “/v1.6/devices/”, DEVICE_LABEL);
sprintf(payload, “%s”, “”); // Cleans the payload
sprintf(payload, “{”%s":", VARIABLE_LABEL); // Adds the variable label
float sensor = analogRead(SENSOR);
dtostrf(sensor, 4, 2, str_sensor);
sprintf(payload, “%s {“value”: %s}}”, payload, str_sensor); // Adds the value
Serial.println(“Publishing data to Ubidots Cloud”);
delay(500);
