Greetings @MASTERCHIEF,
About the device sending the wrong date, it is due to the Decoder function. Its not related to the device. I’ll look into it and correct it.
I think that replacing the timeStampParser function for the following one, will solve the problem:
function timeStampParser(bytes)
var timeStamp = 0;
var years = bytes[4] << 8 | bytes[5] << 0;
var months = bytes[6] - 1;
var days = bytes[7];
var hours = bytes[8];
var minutes = bytes[9];
var seconds = bytes[10];
timeStamp = (Date.UTC(years, months, days, hours, minutes, seconds));
return timeStamp;
Also, can you please confirm that you are using the Helium decoder function shown in the corresponding article section. #3. I just checked the device and it seems to be receiving a payload quite different than the one the decoder is expecting, so it might explain the data location not being correctly parsed.
Best regards
