Hi, I followed the tutorial below: Plugins: Connect The Things Stack to Ubidots to use the TTN and ubidots data but at the moment of creating the plugin it remained in “Starting”.
You can see in the following screenshot
and also when accessing the logs I get the following message
What could be the solution to this problem, or is there something wrong with the configuration that I am overlooking?
The email address associated with the account is: hbjimenez1@utpl.edu.ec
