Quota limit issue
Hi @ginaocoro
Thank you for letting us know about this situation. Please refer to the topic below where we explained what’s happening with the data extraction, we already found the problem and our Dev Team is working on its solution, but this may take some time, so I recommend you close your dashboard when you’re not using it to reduce the consumption of dots out.
Ángela
I have a new variant on the same issue. Again with iSpindel data, but the dots out I have pulled today resulted from my dashboard graph failing to respond to the date range i had entered. I used 4 or five attempts to set a small date range, but the graph kept coming back with all my data.
