Ubidots Community
SCADA widget enable
Hi, I am trying to work out how to enable the SCADA packet as stated in the SCADA tutorial here. Is it due to being on a trial account? If so what tier or membership is required to use it?
Hello, ICAinternetofthings
I hope you’re doing well,
The SCADA widget/package is under beta testing if you would like to give it a try and be part of it I would appreciate you send me a private message with your Ubidots account username so I can enable it for you it doesn’t matter if you are on a trial account.
Kind regards,
-Santiago
Hello santiago,
I’m new to the Ubidots community. I don’t know how to send you a private message, I don’t find a option on your profile to send it. I also need to test the SCADA widget in my Ubidots account. Could you please send me a private message so I can send you my Ubidots account username? I would greatly appreciate it.
Max
Hello, @Max
I sent you a private message last Friday so you can send me your Ubidots account’s username. I will be attentive.
-Santiago
Hi @santiago hope you’re ok.
I’m testing ubidots platform and I’m really interested to work with the SCADA widget. I’ll really appreciate if you can send me a private message to reply with my Ubidots account.
Thank you in advance.
Hello, @alectrl
I have enabled the SCADA widget on your trial account. Please check the following documentation to get started.
Create cloud-based SCADA visualizations in Ubidots.
-Santiago
Hi @santiago
I’m testing ubidots platform and I would like to test the SCADA widget. Can you enable it on my free account?
Hello, @alcos
Thanks for reaching out,
The SCADA widget is at the moment, only available for paid licenses and under the Industrial tier, it is not available for STEM. if you want to try out the widget I suggest you open, it with a different e-mail address, and a new Ubidots account for business purposes and choose then you will have a 30-day free trial.
-Santiago
Hi @santiago
I’m yet in “trial mode” for 30 days (application bitcloud) . But i’m using the same mail used for steam days ago
Hello @alcos
I hope you’re well,
I have enabled the SCADA widget on your account so you can use it on the trial, keep in mind that it is only available for industrial licenses.
-Santiago
Thank you Santiango ! Why, if I may ask, only on industrial version?
Hi, @alcos
As far as I know, It was a business decision given the time and resources invested in its development. As you will see, the SCADA widget is more like an editor where you can create custom visualizations and animations.
-Santiago
Hola @santiago buenas tardes , Yo deseo probar el SCADA widget, lo podrias habilitar porfavor. Tambien quisiera saber si la licencia " Emprendedor de IoT" contiene el SCADA widget. Me podria enviar un mensaje porfavor ya que soy nuevo en la plataforma y no se como enviar un mensaje privado.
Hello Santiago.
Can you tell me how to make the Input value of controls to design in scada only accept numbers?
When I view the scada on my dashboard and click on the box (Input value) to enter a numerical value (0 to 100) this box accepts letters and I only need them to be numbers within the range that I set in my device variable.
How can I do that configuration in my Scada editor?
Thanks for your help.
Greetings
Jefferson
