Hi I am working on a dashboard using the SCADA widget and it is working well except on initial load of the dashboard page the widget does not load the existing values from the Ubidots database and instead waits for new data to come to each variable. Once each variable has changed once it works until the page is changed or reloaded. I saw in this thread this was achived through Javascript but the SCADA widget does not have a custom Javascript option
Hello @ICAinternetofthings,
Would it be possible for you to point us to the dashboard holding said SCADA widget? This would help us troubleshoot and find what could be the issue with that first load.
–David
I have sent you a PM with a link
