Greetings. I was trying to send my data via UDP to Ubidots but my code is generating a device in Ubidot but was not receiving any data.
I am using a Raspberry Pi 3with a cellular IOT shield and code is in python3.
Can anyone please help me.
Greetings, this code may serve you as reference for sending data using UDP:
import socket
import time
import json
import requests
import os
# UBIDOTS PARAMETERS
SERVER = "industrial.api.ubidots.com"
PORT = 9012
BUFFER_SIZE = 1024
TOKEN = ""
def send_packet(token):
try:
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect_ex((SERVER, PORT))
s.settimeout(10)
message = "test/1|POST|{}|".format(token)
message = "{}uptime-monitor:uptime-monitor=>udp:1|end".format(message)
s.send(message.encode())
data = s.recv(BUFFER_SIZE)
print(f'server response: {data}')
s.close()
except Exception as e:
#timeout
print(f'there was an error sending data, details:\n{e}')
