Sending data to Ubidots with feather 32u4 fona
Hi all,
I just received my adafruit feather 32u4 fona. I loaded the example code:
 * Libraries included
#include <SoftwareSerial.h>
#include <stdlib.h>
#include "Arduino.h"
 * Constants and objects
#define DEFAULT_BUFFER_SIZE      64
#define FONA_RX  9
#define FONA_TX  8
#define FONA_RST 4
#define FONA_RI  7
#define SERVER "things.ubidots.com"
#define PORT "80"
#define APN  "TM"  // The APN of your operator
#define USER ""  // if your apn doesnt have username just leave it ""
#define PASS ""  // if your apn doesnt have password just leave it ""
#define TOKEN "**********************"  // Replace it with your Ubidots token
#define METHOD "POST"
#define USER_AGENT  "adafruit"
#define VERSION  "1.0"
#define DEVICE_LABEL  "feather-fona"
#define VARIABLE_LABEL  "temperature"
bool _debug = true;
char buffer[DEFAULT_BUFFER_SIZE];
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
 * Main Functions
    pinMode(A0, INPUT);
    while(!setApn(APN, USER, PASS));
    char* request = (char *) malloc(sizeof(char) * 300);
    char str_val[15];
    float sensor_value = 25;//analogRead(A0);
    dtostrf(sensor_value, 4, 2, str_val);
    sprintf(request, "%s/%s|%s|%s|%s=>%s:%s|end", USER_AGENT, VERSION, METHOD, TOKEN, DEVICE_LABEL, VARIABLE_LABEL, str_val);
    //sprintf(request, "%s|%s|%s","adafruit/1.0|POST", TOKEN, "fona=>test:17.00|end");
    sendToUbidots(request);
    free(request);
 * Auxiliar Functions
bool sendMessageAndwaitForOK(char* message, uint16_t timeout = 4000) {
    fonaSS.println(message);
    if (strstr(readData(timeout), "OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error"));
            return false;
    return true;
bool setApn(char* apn, char* user, char* pwd) {
    checkFona();
    fonaSS.println(F("AT"));
    if (strstr(readData(2000), "OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT"));
        return false;
    fonaSS.println(F("AT+CREG?"));
    if (strstr(readData(2000), "+CREG:") == NULL) {
        if (_debug) {
        return false;
    fonaSS.println(F("AT+CSQ"));
        if (_debug) {
            Serial.println(F("Error with AT+CSQ"));
        return false;
    fonaSS.println(F("AT+CGATT?"));
    if (strstr(readData(10000), "OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+CGATT"));
        return false;
    fonaSS.println(F("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\""));
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR CONTYPE"));
        return false;
    fonaSS.print(F("AT+SAPBR=3,1,\"APN\",\""));
    fonaSS.print(apn);
    fonaSS.println(F("\""));
    if (strstr(readData(3000), "OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR APN"));
        return false;
    fonaSS.print(F("AT+SAPBR=3,1,\"USER\",\""));
    fonaSS.print(user);
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR USER"));
        return false;
    fonaSS.print(F("AT+SAPBR=3,1,\"PWD\",\""));
    fonaSS.print(pwd);
    fonaSS.println("\"");
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR PASSWORD"));
        return false;
    fonaSS.println(F("AT+SAPBR=1,1"));
    if (strstr(readData(4000), "OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR=1,1 Connection ip"));
        return false;
    fonaSS.println(F("AT+SAPBR=2,1"));
    if (strstr(readData(4000), "+SAPBR:") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+SAPBR=2,1 no IP to show"));
        return false;
    return true;
bool module_begin() {
    pinMode(FONA_RST, OUTPUT);
    digitalWrite(FONA_RST, HIGH);
    delay(500);
    digitalWrite(FONA_RST, LOW);
    delay(500);
    delay(500);
    Serial.println(F("Attempting to open comm with ATs"));
    int16_t timeout = 10000;
    while (timeout > 0) {
        if (sendMessageAndwaitForOK("AT"))
            break;
        delay(500);
        timeout -= 500;
    if (timeout <= 0) {
        Serial.println(F("Timeout: No response to AT... last ditch attempt."));
        sendMessageAndwaitForOK("AT");
        delay(100);
        delay(100);
        delay(100);
        return false;
    sendMessageAndwaitForOK("ATE0");
    delay(100);
    return true;
bool sendToUbidots(char* request) {
    fonaSS.println(F("AT+CIPMUX=0"));
        if (_debug) {
            Serial.println(F("Error with AT+CIPMUX"));
        return false;
    fonaSS.print(F("AT+CIPSTART=\"TCP\",\""));
    fonaSS.print(SERVER);
    fonaSS.print(F("\",\""));
    fonaSS.print(PORT);
    if (strstr(readData(4000), "CONNECT OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+CIPSTART"));
        return false;
    fonaSS.print(F("AT+CIPSEND="));
    fonaSS.println(dataLen(request));
    if (strstr(readData(4000), ">") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+CIPSEND"));
        return false;
    fonaSS.write(request);
    if (strstr(readData(4000), "SEND OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error sending variables"));
        return false;
    fonaSS.println(F("AT+CIPCLOSE"));
    if (strstr(readData(4000), "CLOSE OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+CIPCLOSE"));
        return false;
    fonaSS.println(F("AT+CIPSHUT"));
    if (strstr(readData(4000), "SHUT OK") == NULL) {
        if (_debug) {
            Serial.println(F("Error with AT+CIPSHUT"));
        return false;
    return true;
int dataLen(char* variable) {
  uint8_t dataLen = 0;
  for (int i = 0; i <= 250; i++) {
    if (variable[i] != '\0') {
      dataLen++;
      break;
  return dataLen;
bool checkFona() {
    fonaSS.begin(4800);
    module_begin();
    if (!sendMessageAndwaitForOK("ATE0", 6000)) {
        Serial.print("Couldn't find FONA");
        while (1) {
            Serial.println("ERROR");
        return false;
    return true;
char* readData(uint16_t timeout) {
    uint16_t replyidx = 0;
    char replybuffer[254];
    int secconds = 0;
    while (!fonaSS.available() && secconds < timeout) {
        secconds++;
    while (timeout--) {
        if (replyidx >= 254) {
            break;
        while (fonaSS.available()) {
            char c =  fonaSS.read();
            if (c == '\r') continue;
            if (c == 0xA) {
                if (replyidx == 0)   // the first 0x0A is ignored
                    continue;
            replybuffer[replyidx] = c;
            replyidx++;
        while (!fonaSS.available() && timeout > 0) {
            timeout--;
            delay(1);
        if (timeout == 0) {
            if (fonaSS.available()) {
                timeout = 1000;
                break;
    replybuffer[replyidx] = '\0';  // null term
    if (_debug) {
        Serial.println("Response of FONA:");
        Serial.println(replybuffer);
    return replybuffer;
but this is the response:
Response of FONA:
I checked all is ok, if I’m using the fonatest it works and can read signal strengh and sim number
Any idea what I’m doing wrong?
Thank’s for your help
Good day @ecabanas
I hope all is well,
Can you please modify the server, instead of things.ubidots.com please use industrial.api.ubidots.com, and let me know how it goes?
Hi Isabel,
I already done but nothing…One question, do you have any example used with module FOna? I can addapt to se if it’s possible to connect
Hi @ecabanas,
Thanks for your response. Yes, we do have an example of how to connect an Adafruit Feather 32u4 FONA to Ubidots, see the article below.
Hi Isabel,
Thanks for your help, but I already tried and the response from my feather are the same:
Response of FONA:
Error
Response of FONA:
AT
OK
I don’t know what I should do
thanks
