Hi all,
I’ve just bought the Adafruit 32u4 FONA in order to experiment with the GSM/Cellular network. Previously I have used ESP32 and Wifi with good experience using MQTT.
I have spend some time trying to understand why I haven’t been able to upload data with my new FONA device. I have tried different libraries without any succes. When I run the FONAtest examplae I can see that I do have a network with a prober signal strength, so my basic FONA settings works and I do have some network.
I have used this code since it’s the “official” Ubidots code. http://help.ubidots.com/connect-your-devices/connect-an-adafruit-feather-32u4-fona-to-ubidots-over-tcpudp
But it gives me the error code below. It fails during the function “sendToUbidots” and after sending the “AT+CIPSTART” command to FONA.
Do you have any suggestions? I have also tried the Ubidots FONA library but without succes.
Attempting to open comm with ATs
Response of FONA:Error
Response of FONA:
AT
OKCall Ready
SMS Ready
Response of FONA:
ATE0
OKResponse of FONA:
OKAT
Response of FONA:
OK+CREG:
Response of FONA:
+CREG: 0,1OK
AT+CSQ
Response of FONA:
+CSQ: 27,0OK
AT+CGATT?
Response of FONA:
+CGATT: 0OK
AT+SAPBR=3,1,“CONTYPE”,“GPRS”
Response of FONA:
OKAT+SAPBR=3,1,“APN”,"
apn
Response of FONA:
OKAT+SAPBR=3,1,“USER”,"
user
Response of FONA:
OKAT+SAPBR=3,1,“PWD”,"
pwd
Response of FONA:
OKAT+SAPBR=1,1
Response of FONA:
OKAT+SAPBR=2,1
Response of FONA:
+SAPBR: 1,1,“10.222.30.189”OK
SendToUbidots function start:
AT+CIPMUX=0
Line 1
Response of FONA:
OKLine 2
AT+CIPSTART=“TCP”,"
SERVER
PORT
Line 3
Response of FONA:
OKSTATE: PDP DEACT
CONNECT FAIL
Error with AT+CIPSTART
And here is my code (I have added some extra Serial.println)
* Libraries included
#include <SoftwareSerial.h>
#include <stdlib.h>
#include "Arduino.h"
* Constants and objects
#define DEFAULT_BUFFER_SIZE 64
#define FONA_RX 9
#define FONA_TX 8
#define FONA_RST 4
#define SERVER "translate.ubidots.com"
#define PORT "9012"
#define APN "telenor" // The APN of your operator
#define USER "" // if your apn doesnt have username just leave it ""
#define PASS "" // if your apn doesnt have password just leave it ""
#define TOKEN "XXXXXXXXXXXXXXXXXXXXX" // Replace it with your Ubidots token
#define METHOD "POST"
#define USER_AGENT "adafruit"
#define VERSION "1.0"
#define DEVICE_LABEL "feather-fona"
#define VARIABLE_LABEL "temperature"
bool _debug = true;
char buffer[DEFAULT_BUFFER_SIZE];
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
* Main Functions
pinMode(A0, INPUT);
while(!setApn(APN, USER, PASS));
char* request = (char *) malloc(sizeof(char) * 300);
char str_val[15];
float sensor_value = analogRead(A0);
dtostrf(sensor_value, 4, 2, str_val);
sprintf(request, "%s/%s|%s|%s|%s=>%s:%s|end", USER_AGENT, VERSION, METHOD, TOKEN, DEVICE_LABEL, VARIABLE_LABEL, str_val);
//sprintf(request, "%s|%s|%s","adafruit/1.0|POST", TOKEN, "fona=>test:17.00|end");
sendToUbidots(request);
free(request);
* Auxiliar Functions
bool sendMessageAndwaitForOK(char* message, uint16_t timeout = 4000) {
fonaSS.println(message);
if (strstr(readData(timeout), "OK") == NULL) {
if (_debug) {
Serial.println(F("Error"));
return false;
return true;
bool setApn(char* apn, char* user, char* pwd) {
checkFona();
Serial.println("AT");
fonaSS.println(F("AT"));
if (strstr(readData(2000), "OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT"));
return false;
Serial.println("+CREG:");
fonaSS.println(F("AT+CREG?"));
if (strstr(readData(2000), "+CREG:") == NULL) {
if (_debug) {
return false;
Serial.println("AT+CSQ");
fonaSS.println(F("AT+CSQ"));
if (_debug) {
Serial.println(F("Error with AT+CSQ"));
return false;
Serial.println("AT+CGATT?");
fonaSS.println(F("AT+CGATT?"));
if (strstr(readData(10000), "OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+CGATT"));
return false;
Serial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
fonaSS.println(F("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\""));
if (_debug) {
Serial.println(F("Error with AT+SAPBR CONTYPE"));
return false;
Serial.println("AT+SAPBR=3,1,\"APN\",\"");
fonaSS.print(F("AT+SAPBR=3,1,\"APN\",\""));
Serial.println("apn");
fonaSS.print(apn);
Serial.println("\"");
fonaSS.println(F("\""));
if (strstr(readData(3000), "OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+SAPBR APN"));
return false;
Serial.println("AT+SAPBR=3,1,\"USER\",\"");
fonaSS.print(F("AT+SAPBR=3,1,\"USER\",\""));
Serial.println("user");
fonaSS.print(user);
if (_debug) {
Serial.println(F("Error with AT+SAPBR USER"));
return false;
Serial.println("AT+SAPBR=3,1,\"PWD\",\"");
fonaSS.print(F("AT+SAPBR=3,1,\"PWD\",\""));
Serial.println("pwd");
fonaSS.print(pwd);
fonaSS.println("\"");
if (_debug) {
Serial.println(F("Error with AT+SAPBR PASSWORD"));
return false;
Serial.println("AT+SAPBR=1,1");
fonaSS.println(F("AT+SAPBR=1,1"));
if (strstr(readData(4000), "OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+SAPBR=1,1 Connection ip"));
return false;
Serial.println("AT+SAPBR=2,1");
fonaSS.println(F("AT+SAPBR=2,1"));
if (strstr(readData(4000), "+SAPBR:") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+SAPBR=2,1 no IP to show"));
return false;
return true;
bool module_begin() {
pinMode(FONA_RST, OUTPUT);
digitalWrite(FONA_RST, HIGH);
delay(500);
digitalWrite(FONA_RST, LOW);
delay(500);
delay(500);
Serial.println(F("Attempting to open comm with ATs"));
int16_t timeout = 10000;
while (timeout > 0) {
if (sendMessageAndwaitForOK("AT"))
break;
delay(500);
timeout -= 500;
if (timeout <= 0) {
Serial.println(F("Timeout: No response to AT... last ditch attempt."));
sendMessageAndwaitForOK("AT");
delay(100);
delay(100);
delay(100);
return false;
sendMessageAndwaitForOK("ATE0");
delay(100);
return true;
bool sendToUbidots(char* request) {
Serial.println("SendToUbidots function start:");
Serial.println("AT+CIPMUX=0");
fonaSS.println(F("AT+CIPMUX=0"));
Serial.println("Line 1");
if (_debug) {
Serial.println(F("Error with AT+CIPMUX"));
return false;
Serial.println("Line 2");
Serial.println("AT+CIPSTART=\"TCP\",\"");
fonaSS.print(F("AT+CIPSTART=\"TCP\",\""));
Serial.println("SERVER");
fonaSS.print(SERVER);
Serial.println("\",\"");
fonaSS.print(F("\",\""));
Serial.println("PORT");
fonaSS.print(PORT);
Serial.println("Line 3");
if (strstr(readData(4000), "CONNECT OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+CIPSTART"));
return false;
Serial.println("Line 4");
Serial.println("AT+CIPSEND=");
fonaSS.print(F("AT+CIPSEND="));
Serial.println("Line 5");
fonaSS.println(dataLen(request));
if (strstr(readData(4000), ">") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+CIPSEND"));
return false;
fonaSS.write(request);
if (strstr(readData(4000), "SEND OK") == NULL) {
if (_debug) {
Serial.println(F("Error sending variables"));
return false;
fonaSS.println(F("AT+CIPCLOSE"));
if (strstr(readData(4000), "CLOSE OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+CIPCLOSE"));
return false;
fonaSS.println(F("AT+CIPSHUT"));
if (strstr(readData(4000), "SHUT OK") == NULL) {
if (_debug) {
Serial.println(F("Error with AT+CIPSHUT"));
return false;
return true;
int dataLen(char* variable) {
uint8_t dataLen = 0;
for (int i = 0; i <= 250; i++) {
if (variable[i] != '\0') {
dataLen++;
break;
return dataLen;
bool checkFona() {
fonaSS.begin(4800);
module_begin();
if (!sendMessageAndwaitForOK("ATE0", 6000)) {
Serial.print("Couldn't find FONA");
while (1) {
Serial.println("ERROR");
return false;
return true;
char* readData(uint16_t timeout) {
uint16_t replyidx = 0;
char replybuffer[254];
int secconds = 0;
while (!fonaSS.available() && secconds < timeout) {
secconds++;
while (timeout--) {
if (replyidx >= 254) {
break;
while (fonaSS.available()) {
char c = fonaSS.read();
if (c == '\r') continue;
if (c == 0xA) {
if (replyidx == 0) // the first 0x0A is ignored
continue;
replybuffer[replyidx] = c;
replyidx++;
while (!fonaSS.available() && timeout > 0) {
timeout--;
delay(1);
if (timeout == 0) {
if (fonaSS.available()) {
timeout = 1000;
break;
replybuffer[replyidx] = '\0'; // null term
if (_debug) {
Serial.println("Response of FONA:");
Serial.println(replybuffer);
return replybuffer;
