Mike - You indicated you were able to send data to Ubidots. I have been unsuccessful in doing so. Can you share your entire code. Im just using the code from the example in the tutorial and im only passing one value which for now I hard coded.
http://ubidots.com/docs/devices/FONA.html#devices-fona
… with no luck. I keep getting failed
Here is my Code:
#include <SoftwareSerial.h>
#include “Adafruit_FONA.h”
#include <stdlib.h>
// Pin connections:
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
#define FONA_KEY 7
#define FONA_PS 8
// Ubidots token and variables
char token[] = “twG9BwrMyj23KL455VXxRQGdZ89Q06”;
char id1[] = “56910c787625423044885ab2”;
//char id2[] = “”;
//char id3[] = “”;
//char id4[] = “”;
// this is a large buffer for replies
char replybuffer[255];
// or comment this out & use a hardware serial port like Serial1 (see below)
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
int get_int_len(int);
void sendDataUbidots(void);
int value1, value2, value3, value4;
char buffer [33];
//For FONA MODULE
fonaSS.begin(4800);
pinMode(FONA_KEY, OUTPUT);
pinMode(FONA_PS, INPUT);
analogReference(INTERNAL);
TurnOffFona();
flushSerial();
TurnOnFona();
checkFona();
gprsOnFona();
senseValues();
while (fona.available()) {
Serial.write(fona.read());
gprsOffFona();
TurnOffFona();
delay(600000);
void senseValues(){
value1 = 78;
//value1 = analogRead(A6);
//value2 = analogRead(A7);
//value3 = analogRead(A0);
//value4 = analogRead(A1);
sendDataUbidots(value1, id1);
//sendDataUbidots(value2, id2);
//sendDataUbidots(value3, id3);
//sendDataUbidots(value4, id4);
void sendDataUbidots(int value, char* myid){
uint16_t statuscode;
int16_t length;
char url1[] = “things.ubidots.com/api/v1.6/variables/”;
char* url2 = myid;
char url3[] = “/values?token=”;
char* url4 = token;
int lurl = strlen(url1) + strlen(url2) + strlen(url3) + strlen(url4);
char url[lurl];
sprintf(url,"%s%s%s%s",url1,url2,url3,url4);
// Serial.println(url);
char data1[] = “{“value”:”;
char data2[get_int_len(value)+1];
char data3[] = “}”;
itoa(value,data2,10);
int ldata = strlen(data1) + strlen(data2) + strlen(data3);
char data[ldata];
sprintf(data,"%s%s%s",data1,data2,data3);
//Serial.println(data);
Serial.print(F(“http://”));
Serial.println(F("****"));
if (!fona.HTTP_POST_start(url, F(“application/json”), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
Serial.println(“Failed!”);
while (length > 0) {
char c = fona.read();
#if defined(AVR_ATmega328P) || defined(AVR_ATmega168)
loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
UDR0 = c;
#else
Serial.write©;
#endif
length--;
if (! length) break;
Serial.println(F("\n****"));
fona.HTTP_POST_end();
// flush input
flushSerial();
void flushSerial() {
while (Serial.available())
Serial.read();
char readBlocking() {
while (!Serial.available());
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print©;
Serial.print©;
x = c - ‘0’;
while (isdigit(c = readBlocking())) {
Serial.print©;
x *= 10;
x += c - ‘0’;
return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
uint16_t buffidx = 0;
boolean timeoutvalid = true;
if (timeout == 0) timeoutvalid = false;
while (true) {
if (buffidx > maxbuff) {
//Serial.println(F(“SPACE”));
break;
while(Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) // the first 0x0A is ignored
continue;
timeout = 0; // the second 0x0A is the end of the line
break;
buff[buffidx] = c;
buffidx++;
if (timeoutvalid && timeout == 0) {
//Serial.println(F("TIMEOUT"));
break;
delay(1);
buff[buffidx] = 0; // null term
return buffidx;
int get_int_len (int value){
int l=1;
while(value>9){ l++; value/=10; }
return l;
void checkFona(){
// See if the FONA is responding
if (! fona.begin(fonaSS)) { // can also try fona.begin(Serial1)
Serial.println(F(“Couldn’t find FONA”));
while (1);
Serial.println(F(“FONA is OK”));
//configure a GPRS APN
fona.setGPRSNetworkSettings(F(“epc.tmobile.com”), F(""), F(""));
//fona.setGPRSNetworkSettings(F(“fast.t-mobile.com”), F(""), F(""));
void TurnOnFona(){
Serial.println("Turning on Fona: ");
while(digitalRead(FONA_PS)==LOW)
digitalWrite(FONA_KEY, LOW);
digitalWrite(FONA_KEY, HIGH);
delay(4000);
void TurnOffFona(){
Serial.println("Turning off Fona ");
while(digitalRead(FONA_PS)==HIGH)
delay(4000);
void gprsOnFona(){
while(!fona.enableGPRS(true));
Serial.println(F(“Turn on”));
void gprsOffFona(){
while (!fona.enableGPRS(false));
Serial.println(F(“Turn off”));
