[SOLVED] Adding context while publish
Hello, I am establishing an MQTT connection and publishing it to the Ubidots dashboard. I want to just add the Context like “Motion Detected” while publishing.
And I am using this code in Arduino IDE with ESP32:
  reconnect();
  sprintf(payload, "{\"%s\":", VARIABLE_LABEL); // Adds the variable label
  float sensor = analogRead(sensor);
  dtostrf(sensor, 4, 2, str_sensor);
  sprintf(payload, "%s {\"value\": %s}}", payload, str_sensor); // Adds the value
In Dashboard, I am getting ----- line in place of context.
So what changes I have to make in the above code? Please help me out.
Hi there, you may refer to the GPS tracker example here.
Sorry for late response, and Thank you so much for the help. And now I am able to do what I wanted. Thanks again
