[SOLVED] Arduino-GPRS, couldn't send Lat and long over to ubidots
I have done a program with the arduino GPRS, I got the lat and long,however I cant send over to Ubidots, anyone can help me? Thank you so much.
here’s the code:
#include <SIM900.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
TinyGPS gps;
SoftwareSerial ss(10, 11);
char token[] = “SYPO3pL3OtCl5Axbd6ueBZcDTrRE9pWrZcxPwjXuipbWhMpkaAXnFgtfBSI8”; //your token to post value
char idvariable[] = “5610da05762542729c789a19”;
float flat, flon;
unsigned long age;
ss.begin(9600);
gsm.begin(9600);
gps.f_get_position(&flat, &flon, &age);
readGPS(gps);
// uncomment to test if gps is working
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
save_value("123");
static void print_int(unsigned long val, unsigned long invalid, int len)
char sz[32];
if (val == invalid)
strcpy(sz, “*******”);
else
sprintf(sz, “%ld”, val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ’ ';
if (len > 0)
sz[len-1] = ’ ';
Serial.print(sz);
smartdelay(0);
//this function is to send the sensor data to the Ubidots, you can see the new value in the Ubidots after execute this function
void save_value(char* valor)
gsm.listen();
int num;
String le;
char temp[50];
//num=var.length();
le=String(num);
for(int i = 0;i<7;i++)
gsm.SimpleWriteln(“AT+CGATT?”); //it is made repeatedly because it is unstable
ShowSerialData();
// gsm.SimpleWriteln(“AT+CSTT=“sunsurf””); //start task and setting the APN
gsm.SimpleWriteln(“AT+CSTT=“sunsurf”,“65”,“user123”);
ShowSerialData();
gsm.SimpleWriteln(“AT+CIICR”); //bring up wireless connection
delay(3000);
ShowSerialData();
gsm.SimpleWriteln(“AT+CIFSR”); //get local IP adress
ShowSerialData();
gsm.SimpleWriteln(“AT+CIPSPRT=0”);
delay(3000);
ShowSerialData();
gsm.SimpleWriteln(“AT+CIPSTART=“tcp”,“things.ubidots.com”,“80"”); //start up the connection
delay(3000);
ShowSerialData();
gsm.SimpleWriteln(“AT+CIPSEND”); //begin send data to remote server
delay(3000);
ShowSerialData();
sprintf(temp,“POST /api/v1.6/variables/%s/values HTTP/1.1”,idvariable);
gsm.SimpleWriteln(temp);
// gsm.SimpleWrite(“POST /api/v1.6/variables/”+idvariable);
// delay(100);
// ShowSerialData();
// gsm.SimpleWriteln(”/values HTTP/1.1”);
delay(100);
ShowSerialData();
gsm.SimpleWriteln(“Content-Type: application/json”);
delay(100);
ShowSerialData();
gsm.SimpleWriteln(“Content-Length: “+sizeof(temp));
delay(100);
ShowSerialData();
sprintf(temp,“X-Auth-Token: %s”,token);
delay(100);
ShowSerialData();
gsm.SimpleWriteln(“Host: things.ubidots.com”);
delay(100);
ShowSerialData();
gsm.SimpleWriteln(””);
delay(100);
ShowSerialData();
sprintf(temp,"{“value”:%s}",valor);
delay(100);
ShowSerialData();
gsm.SimpleWriteln("");
delay(100);
ShowSerialData();
gsm.SimpleWriteln((char)26);
delay(7000);
ShowSerialData();
gsm.SimpleWriteln(“AT+CIPCLOSE”); //close the communication
ShowSerialData();
void ShowSerialData()
while(gsm.available()!=0)
Serial.write(gsm.read());
void readGPS(TinyGPS &gps)
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE){
// no signal
else
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
month, day, year, hour, minute, second);
Serial.print(sz);
Serial.print("Lat: “);Serial.print(flat);Serial.print(”, Lon: ");Serial.println(flon);
smartdelay(0);
void smartdelay(unsigned long ms)
ss.listen();
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
Can you see some data in your account?
Gustavo
Hi,I can’t see. I have tried sending battery levels it worked however when I try on the gps it can’t send the coordinates over.
Hi there,
Are you actually sending GPS data? I see this line where you only send the value, no lat or long data:
sprintf(temp,"{\"value\":%s}",valor);
Check out: http://ubidots.com/docs/get_started/quickstart/tutorial_geopoint.html you should send lat and lng coordinates, for example:
sprintf(temp,"{\"value\":%s, \"context\":{\"lat\":%s,\"lng\":%s}}",valor, lat, long);
I don’t know if this line compiles, it depends on the variables names you use in the code and the sprintf syntax, but it’s just to give you an idea.
This is easier to do by using our library http://ubidots.com/docs/devices/gprs.html
