[SOLVED] Cant get Collections to work with Arduino
Hi guys. I’m trying to figure out a way to update (POST) 2 or more variables using Collections (as suggested in this topic: http://community.ubidots.com/t/how-to-implement-2-variables-with-the-sim900/110/4). The issue in that topic was not resolved so I’m basically asking the question again. What is the correct way of posting multiple variables within one POST command using Collections and an Arduino board.
Here is my code, for the reference:
  #include VirtualWire.h
  #include Wire.h
  #include SPI.h
  #include Ethernet.h
  byte mac[] = { 0xD4, 0x28, 0xB2, 0xFF, 0xA0, 0xA1 }; // Must be unique on local network
  // Initialize the Ethernet client library
  // with the IP address and port of the server
  // that you want to connect to (port 80 is default for HTTP):
  EthernetClient client;
  // Inicializacija spremenljivk
  String temperatura = (""); //Init za String sporocilo
  bool meritev = false; //ali je prisprela nova RF meritev?
  // Nastavitve za oblak
  String idvariable1 = "565cbeb07625422e68139107";
  String idvariable2 = "565cc36b76254239c5b67cea";
  String token = "BDYIvU87JspcOyaabxFRcv3Q207qWKRa4fp6yMlOZvMtY3bMzRBVcVuLCoS8";
    //Odprem serial port za debug
    //Define the receiver pin and rate
    vw_set_rx_pin(12);        //Sets pin D12 as the RX Pin
    vw_setup(2000);           // Bits per sec
    vw_rx_start();            // Start the receiver PLL running
      // no point in carrying on, so do nothing forevermore:
      for (;;);
    Serial.println("connecting...");
  void loop()
    //Photoresistor (field2)
    int photoSens = digitalRead(7);
    if (photoSens == 1) {
      photoSens = 0;
      photoSens = 1;
    //Temperature monitor preko RF433MHz
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if ( vw_get_message(buf, &buflen) )
      temperatura = (""); //reset temperature
      meritev = true; //prispela nova meritev! Update oblak!
      Serial.print("Temp2 [C]: ");
      int i;
      for (i = 0; i < buflen; i++)
        char vrednost = ((char)buf[i]);
        temperatura = temperatura + String(vrednost);
      temperatura.trim();
      Serial.println(temperatura);
    //Osvežimo podatke v oblaku
    if (meritev == true)
      save_value(String(temperatura), String(photoSens));
      meritev = false; //reset RF meritve
  void save_value(String value1, String value2)
    int num = 0;
    String var = "[{\"variable\":" + idvariable1 + ", \"value\":" + value1 + "}, {\"variable\":" + idvariable2 + ", \"value\":" + value2 + "}]";
    num = var.length();
    if (client.connect("things.ubidots.com", 80))
      Serial.println("connected");
      // New lines according to ubidots support:
      client.println("POST /api/v1.6/collections/values HTTP/1.1");
      Serial.println("POST /api/v1.6/collections/values HTTP/1.1");
      client.println("Accept: application/json; indent=4");
      Serial.println("Accept: application/json; indent=4");
      Serial.println("Content-Type: application/json");
      client.println("Content-Length: " + String(num));
      Serial.println("Content-Length: " + String(num));
      client.println("X-Auth-Token: " + token);
      Serial.println("X-Auth-Token: " + token);
      Serial.println("Host: things.ubidots.com\n");
      client.print(var);
      Serial.print(var + "\n");
      Serial.println("Konec prenosa!");
    else
    if (!client.connected())
      client.stop();
    if (client.available())
      char c = client.read();
      Serial.print(c);
    client.flush();
    client.stop();
Check out our new Arduino Ethernet library: https://github.com/ubidots/ubidots-arduino-ethernet
