hey everyone, am new to using the api’s, am planning to send data from the arduino GSM shield as instructed in the website with context info, but whenevr i try to include the context in the variable field i get bad request response, here is my code
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// APN data
#define GPRS_APN "internet" // replace with your GPRS APN
#define GPRS_LOGIN "guest" // replace with your GPRS login
#define GPRS_PASSWORD "guest" // replace with your GPRS password
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
uint16_t reset = 0;
String idvariable = "56730183762542244ad83305"; // replace with your Ubidots Variable ID
String token = "Xb3ahJbNM8vPXMDGZ7oNBmnnvLIHMfd7hOvKt0ftiORBVLl5ok56OBlNEp85"; // replace with your Ubidots token
//Location where this logger is placed!!
String loclat=“19.21833”;
String loclng=“72.978088”;
String Location;
void setup()
// initialize serial communications and wait for port to open:
while (!Serial) {
Serial.println("Starting Arduino web client.");
Location="{\"lat\":";
Location=Location+loclat;
Location += " ,“lng”:";
Location=Location+loclng+ “}”;
// connection state
boolean notConnected = true;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (notConnected)
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY))
notConnected = false;
else
Serial.println("Not connected");
void loop()
int value = 21;
if(save_value(value,Location))
else
reset++;
if (reset == 10)
asm volatile (" jmp 0"); // reset the Arduino board if the data transmission fail
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected())
client.stop();
// do nothing forevermore:
boolean save_value(int value,String Location)
Serial.println("connecting...");
int num=0;
String var = "{\"value\":"+ String(value) + ",\"context\":"+ Location +"}";
Serial.println(var);
num = var.length();
if (client.connect("things.ubidots.com", 80))
Serial.println("connected");
// Make a HTTP request:
client.print("POST /api/v1.6/variables/"+idvariable+"/values HTTP/1.1\nContent-Type: application/json\nContent-Length: "+String(num)+"\nX-Auth-Token: "+token+"\nHost: things.ubidots.com\n\n");
client.println(var);
client.println();
else
// if you didn’t get a connection to the server:
Serial.println(“connection failed”);
return false;
while (client.available())
char c = client.read();
Serial.print(c);
so please how can i include the context with the variables am letterly hopeless
