Is there a widget or a way to see how many dots one has sent during the day? Is there any notification if you exceed the 4000 daily limit?
Thank You
John
Hey @ardyjohn,
To calculate the total data received in a day I recommend you to create a Synthetic Variable that takes care of counting the total of dots received on a variable. For this, you should use the “count” function.
Then you can configure an event based on the Synthetic Variable to generate the desired alert. Also, add the widgets you desire on the dashboard.
I hope this is helpful to you.
Greetings,
Maria H.
Thanks Maria,
That might be beyond my comprehension, but I’ll see.
John
I’m here to support you, so if you have any other questions, just let me know.
Cheers,
Maria H.
