Hello, I am working on a project and I faced a problem in getting the action after done during subscribe. I have a server on ESP32 which is connected to Ubidots for publishing and subscribing. 2 clients with ESP8266 are connected with it with flame sensor and magnetic switch respectively. Now I am trying to subscribe the clients, but I am having a problem. As per me, there is time delay of around 1.5mins. So is there is any solution for this?
this is the setup and loop part:
WiFi.begin(ssid, password);
// Assign the pin as OUTPUT
pinMode(RELAY, OUTPUT);
Serial.print(".");
delay(500);
Serial.println("");
Serial.println(F("Server started"));
client.setCallback(callback);
sprintf(topicSubscribe, "/v1.6/devices/%s/%s/lv", DEVICE_LABEL, VARIABLE_LABEL_SUBSCRIBE); // This is the format to Subscribe Values :- /v1.6/devices/[device label]/[variable label]/lv
client.subscribe(topicSubscribe);
//wifi_connect();
// Flame Sensor mode INPUT_PULLUP
pinMode(fireSensor, INPUT_PULLUP);
// Set fireSensor pin as interrupt, assign interrupt function and set RISING mode
attachInterrupt(digitalPinToInterrupt(fireSensor), detectsFire, RISING);
pinMode(4, OUTPUT);
//wifi_connect();
if (system_enable && cmd){
//if(cmd){
send_command("fire");
digitalWrite(4, HIGH);
digitalWrite(4, LOW);// for switching OFF the buzzer afetr 5000 ms
cmd = false;
Hi @gargashi,
I hope all is well.
Can you please let us know which mqttbroker (URL) are you using to subscribe to Ubidots variables? Additionally, are you using any specific libraries?
mqtt broker= industrial.api.ubidots.com
Libraries: ESP8266WiFi.h
PubSubClient.h
cmd: in the program is the command going to server(ESP32)
#include <ESP8266WiFi.h>
#include "PubSubClient.h"
#define PORT 80
char* ssid = "*******";
char* password = "******";
#define TOKEN "*********"
#define MQTT_CLIENT_NAME "*****"
#define DEVICE_LABEL "******" // Assig the device label
#define VARIABLE_LABEL_SUBSCRIBE "relay" // Assing the variable label
#define RELAY 16 // Set the GPIO16 as RELAY
bool system_enable = 1;
extern bool system_enable;
char mqttBroker[] = "industrial.api.ubidots.com";
char payload[100];
char topic[150];
char topicSubscribe[100];//To store the topic from which the message is subscribed
WiFiServer server(PORT);
WiFiClient esp_client;
WiFiClient ubidots;
PubSubClient client(ubidots);
int ex = 0;
String req;
const char* host = "***.***.**.**";
const uint16_t port = 80;
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
if (message == "0") {
system_enable = false;
//digitalWrite(RELAY, LOW);
Serial.println("System is disabled");
system_enable = true;
//digitalWrite(RELAY, HIGH);
Serial.println("System is enabled");
Serial.println(topic);
void reconnect() {
while (!client.connected()) {
// Attemp to connect
Serial.println("Connected");
Serial.print("Failed, rc=");
Serial.print(client.state());
// Set GPIOs for fireSensor
const int fireSensor = 5;
bool cmd = false;
// Checks if motion was detected, sets LED HIGH and starts a timer
ICACHE_RAM_ATTR void detectsFire()
Serial.println("Fire Alarm!!!");
cmd = true;
Hello, thank you, I solved my problem, now I am not getting any delay. I was making some mistakes. Thanks again, for this good community.
Hi @gargashi,
Glad to hear you were able to solve it.
Have a nice day,
Hi
My Name is Said , could you please explain what were the mistakes that you solved the problem of delay
in receiving subscriptions
Thank you
Hello Said, actually now I didn’t remember the actual mistake. But probably there was silly mistake in code from my side. It was not any big mistake. Please check your code line by line & match with examples given on Ubidots Help Centre. You can figure it out.
