mafify
                    March 28, 2018,  6:10am
              1
              Hello, I want to make a command to delete all the values of the variable through a HTTP DELETE request
I though of putting an old date like 1/1/2010 inthe {START}
and a future data like 1/1/2020 in the {END}
the #request  is
“http://things.ubidots.com/api/v1.6/variables/my_variable/values/1262326171000/1577858971000/?token=my_token ”
and the Response I got is
"count ": 0
what is the issue and if it’s because the TIMESTAMP is the reason, is there a way to make an HTTP request to delete all the values
              Please make sure that your start and end timestamp are setting up properly (they must be in milliseconds), I have made a small test and at my side it works properly:
                mafify
                    March 29, 2018,  5:58am
              3
              Greetings, if you get a count=0 it means that there are no dots in your date range, make sure that your start and end timestamps are correct.
