Hi, I am Jashwa. I was working on arduino and esp-01 module to post some data to my variables. I am using the Fixed IP to connect using the TCP protocol and the port i am using is 443 to secure transfer. No matter what i do I am not able to get data into my variable. Please take a look and suggests an edit.
This is my code as of now and I am not using any libraries
#include<SoftwareSerial.h>
SoftwareSerial a(10,11);
String ssid="Honor 8 Pro"; // Wifi network SSID
String pass = "mummy007";
char payload[200];
char str_val_1[30];
char const * VARIABLE_LABEL_1 = "b";
void showResponse(int waitTime){
long t=millis();
char c;
while (t+waitTime>millis()){
if (a.available()){
c=a.read();
Serial.print(c);
a.begin(115200);
float sensor_value_1 = random(0, 1000)*1.0;
/*---- Transforms the values of the sensors to char type -----*/
/* 4 is mininum width, 2 is precision; float value is copied onto str_val*/
dtostrf(sensor_value_1, 4, 2, str_val_1);
// Important: Avoid to send a very long char as it is very memory space costly, send small char arrays
sprintf(payload, "{\"");
sprintf(payload, "%s%s\":{\"value\":%s}", payload, VARIABLE_LABEL_1, str_val_1);
//Serial.println(payload);
int contentLength = strlen(payload);
a.println("AT+RST\r\n"); // set esp8266 as client
showResponse(10000);
a.println("AT+CWMODE=3\r\n"); // set esp8266 as client
a.println("AT+CWJAP=\""+ssid+"\",\""+pass+"\"\r\n"); // set your home router SSID and password
a.println("AT+CIPMODE=0\r\n");
a.println("AT+CIPMUX=0\r\n");
String cmd = "AT+CIPSTART=\"TCP\",\""; // TCP connection
cmd += "169.55.61.243"; // api.thingspeak.com
cmd += "\",443\r\n";
a.println(cmd);
String getStr = "POST /api/v1.6/devices/a HTTP/1.1\r\nHost: things.ubidots.com\r\nUser-Agent: ESP8266/1.0\r\nX-Auth-Token: BBFF-rV13gArzJADwfGmU9wzeTVi0M1VCFQ\r\nConnection: close\r\nContent-Type: application/json\r\nContent-Length: ";
getStr += contentLength;
getStr += "\r\n\r\n";
getStr += payload;
getStr += "\r\n";
cmd = "AT+CIPSEND=";
cmd += String(getStr.length());
a.println(cmd);
a.println(getStr);
When I remove the Content length and the payload there is no 400 Bad request but Send OK messge
But when I try to send the whole command with Content length and payload I am getting this error
This is my response
AV+CIPSTART="VCP","169.55'61.243",443CC⸮CC!⸮]⸮^⸮⸮ryj
COONECT
OK
AT+CIPSEND=21c
OK
busy s../
Recv 213 bytes
SF⸮D OK
+IPD,409:HTTP/1.1 400 Bad Requesv
Server: ng⸮nx
Date: Qat, 01 De8 et
n
:k⸮
ieB⸮Ձ͕⸮Q<e⸮⸮⸮⸮ɥ⸮
