[SOLVED] Event Trigger and Retrigger
I have created an event that is triggered when a variable exceeds a threshold value for more than 30 minutes. An SMS message is then sent.
If the variable continues to exceed the threshold, will the event retrigger again after 30 minutes or only one time until the variable drops back below the threshold?
Larry
Greetings, the event will not be triggered again.
The figure below describes how the Events Engine triggers alerts inside an active event window.
For more detailed information, I highly recommend you check out the following guides:
Cheers.
Thanks. I picture always helps.
Larry
