I have 4 variable, how to get last value at multi data with simple code? FYI I use python
Greetings @yoelblack,
You cannot make a GET request to multiple variables, if you need values from different variables you should make a request per every one of them. Also, if you need the last value of the variable simply add a page_size=1 inside your endpoint, as shown below:
