Hello, i got a message error while sending data flow meter sensor from raspberry pi to ubidots server
flowval.save_value({‘value’:flow})
AttributeError: ‘NoneType’ object has no attribute ‘save_value’
Here my codes :
import serial
import time
from ubidots import ApiClient
import random
serPort = serial.Serial(‘/dev/ttyACM0’, 9600)
dS = None
def getVarbyNames(varName,dS):
for var in dS.get_variables():
if var.name == varName:
return var
return None
try:
api = ApiClient(“43936d6645f2b8455336df48b448edc945fa3c07”)
for curDs in api.get_datasources():
if curDs.name == “HidroponikTA”:
ds = curDs
break
if dS is None:
dS = api.create_datasource({“name”:“HidroponikTA”})
lightval = getVarbyNames(“Light”,dS)
if lightval is None:
lightval = dS.create_variable({“name”:“Light”,“unit”:“lux”})
humidityval = getVarbyNames(“Humidity”, dS)
if humidityval is None:
humidityval = dS.create_variable({“name”:“Humidity”,“unit”:“%”})
tempval = getVarbyNames(“Temperature”, dS)
if tempval is None:
tempval = dS.create_variable({“name”:“Temperature”,“unit”:“C”})
phval = getVarbyNames(“PH”, dS)
if phval is None:
phval = dS.create_variable({“name”:“PH”,“unit”:" "})
flowval = getVarbyNames(“Flow”, dS)
if flow is None:
flow = dS.create_variable({“name”:“Flow”,“unit”:“L/h”})
except:
print(“cant connect”)
while True :
sensorRead = serPort.readline()
sensorVar = sensorRead.split(" ")
light = int(sensorVar[0])
humidity = float(sensorVar[1])
temp = float(sensorVar[2])
ph = float(sensorVar[3])
flow = int(sensorVar[4])
var = ‘light: %d , humidity: %f , temp: %f , ph: %f , flow: %d’ % (light, humidity, temp, ph, flow)
print var
lightval.save_value({‘value’:light})
humidityval.save_value({‘value’:humidity})
tempval.save_value({‘value’:temp})
phval.save_value({‘value’:ph})
thanks
