Hello everyone,
Im making a project, I am using UBIDOTS to display the status online. I am using an Arduino mega and Arduino gsm shield. Using the example code given by UBIDOTS, I have managed to send some integer values and this works perfectly however I cannot get my Xbee code integrated into the gsm code. The Xbee code is receiving data from a reedswitch and sending it wirelessly to the other xbee. Below is the code for the xbee. When the data is uploaded onto the cloud I need it to be in characters. Thanks in advance
Xbee coding:
int readValue = 0;
int x;
if(Serial.available() > 13) {
//Serial.println(Serial.read(), HEX);
for(int i=0; i<14; i++) {
x =Serial.read();
// Serial.print("i= ");
// Serial.print(i);
// Serial.print(" ");
// Serial.print(x,HEX);
if (i == 12)
{ if (x == 0)
{Serial.println(" LOW");}
else {Serial.println(" HIGH"); } }
GSM code by UBIDOTS:
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// APN data
#define GPRS_APN "sm2ms.movilforum.es" // replace with your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
uint16_t reset = 0;
String idvariable = "565c7ce5762542029c2b9c47"; // replace with your Ubidots Variable ID
String token = "WIsjN9xzR8s8p2lwHa4VK7Eiu8phegFtlFBCCwtQiC2RITN4XcKWjIWAiR7U"; // replace with your Ubidots token
void setup()
// initialize serial communications and wait for port to open:
while (!Serial) {
Serial.println("Starting Arduino web client.");
// connection state
boolean notConnected = true;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (notConnected)
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY))
notConnected = false;
else
Serial.println("Not connected");
void loop()
int value = 9860;
if(save_value(value))
else
reset++;
if (reset == 10)
asm volatile (" jmp 0"); // reset the Arduino board if the data transmission fail
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected())
client.stop();
// do nothing forevermore:
boolean save_value(int value)
Serial.println("connecting...");
int num=0;
String var = "{\"value\":"+ String(value) + "}";
num = var.length();
if (client.connect("things.ubidots.com", 80))
Serial.println("connected");
// Make a HTTP request:
client.print("POST /api/v1.6/variables/"+idvariable+"/values HTTP/1.1\nContent-Type: application/json\nContent-Length: "+String(num)+"\nX-Auth-Token: "+token+"\nHost: things.ubidots.com\n\n");
client.println(var);
client.println();
else
return false;
while (client.available())
char c = client.read();
Serial.print(c);
