I am puzzled about “POST api/v1.6/variables/{variable_id}/values”
I don’t want to post each variable separately via unique URL? Who came up with that?
I would like to use JSON as it was meant where each variable ID and it’s value is part of a JSON pair instead of using the generic variable ID “value” and doing it the hard way with unique URL for each?
Sure, there’s also an endpoint for that case. We call it “collections” as it is mostly used to update many variables in a single request, but you can also use it for one variable.
Here’s an example using curl, it should actually work if you copy-paste it in your terminal:
