[SOLVED] How turn on a LED with ADUINO UNO + Ethernet Shield
Hi.
I have been checking some examples of how to turn on a LED from the DASHBOARD, however, those examples only works with an ARDUINO WI-FI shield. I want to know how to do this whit a Ethernet Shield.
Thank you.
Hola.
He estado revisando los ejemplos para encender un LED desde el DASHBOARD, sin embargo, estos ejemplos solo aplican para conexión WI-FI, quisiera saber de que manera puedo lograrlo utilizando un shield Ethernet.
Gracias
Hello @david_espeleta were you able to achieve this?
Usually you would make a GET request to the variable URL, add a parameter to get only one value, then parse the response. This is a sample request:
GET /api/v1.6/variables/YOUR-VAR-ID/values?token=YOUR-TOKEN&page_size=1
This will return a JSON payload, where you can run a string search for “value” and then get the value that is after the “:” character.
Check out our new Ethernet library which supports the GET command https://github.com/ubidots/ubidots-arduino-ethernet
