Hi.
I´ve been trying to test the Ubidots example code for the Goblin 2 board, I put in my token, ID variable and APN, but serial monitor only show hieroglyphics at 9600 Bauds, and if I change it to 115200 Bauds show me this.
START
+STIN: 25
+STIN: 25
+CPIN: READY
+STIN: 25
SMS DONE
+VOICEMAIL: INIT_STATE, 0, 0
PB DONE
This is my code.
#include <SoftwareSerial.h>
SoftwareSerial SIM5320(5, 4); //RX, TX
char BUFFER_USART; //BUFFER RX
String token = "BBFF-wZ2pGiSWY8csJO60O1XXXXXXXXXXXX"; //TOKEN UBIDOTS
String id = "5bf094d41d8472262XXXXXXX"; //ID VARIABLE UBIDOTS
pinMode(5, OUTPUT); //PIN ON SIM5320
SIM5320.begin(9600);
SIM5320_ON(); //ON SIM5320
delay(10000);
SETUP_SIM5320(); //START SIM5320
WEB(); //SEND JSON UBIDOTS
delay(1000); //SAMPLE TIME
ISR (USART_RX_vect)
BUFFER_USART = UDR0; // READ THE BUFFER RX
void WEB()
int LONG_JSON = 15;
int SEND = 214;
float temp = 20.0;
SIM5320.println(F("AT+CIPOPEN=0,\"TCP\",\"things.ubidots.com\",80")); //
SIM5320.print("AT+CIPSEND=0,"); //
delay(50);
SIM5320.println(SEND); //
delay(600);
SIM5320.print(F("POST /api/v1.6/variables/"));
delay(50);
SIM5320.print(id);
delay(50);
SIM5320.println(F("/values HTTP/1.1"));
delay(50);
SIM5320.println(F("Content-Type: application/json"));
delay(50);
SIM5320.print(F("Content-Length:"));
delay(50);
SIM5320.println(LONG_JSON);
delay(50);
SIM5320.print(F("X-Auth-Token: "));
delay(50);
SIM5320.println(token);
delay(50);
SIM5320.println(F("Host: things.ubidots.com"));
delay(50);
SIM5320.println("");
SIM5320.print("{\"value\":");
delay(10);
SIM5320.print(temp,2);
delay(50);
SIM5320.println("}");
delay(50);
SIM5320.write(0x1A);
SIM5320.println(F("AT+CIPCLOSE=0"));
delay(4000);
void SIM5320_ON()
digitalWrite(5, HIGH);
delay(2000);//
digitalWrite(5, LOW);
void SETUP_SIM5320()
SIM5320.println(F("AT+CFUN=1")); //SIM5320 WORKING WITH ALL THE FEATURES
delay(250);
SIM5320.println(F("AT+CNMP=2")); //AUTOMATIC MODE
delay(250);
SIM5320.println(F("AT+CVAUXV=61")); //3.0V OUTPUT VOLTAGE
delay(250);
SIM5320.println(F("AT+CNBP=0x0000000004000000")); //3G 850MHZ TELCEL 0x0000000004000000 hspda 2G 1900MHZ TELCEL AT+CNBP=0x0000000000200000 edge
delay(500);
SIM5320.println(F("AT+CSQ")); //SIGNAL LEVEL
delay(250);
SIM5320.println(F("AT+CREG?"));
delay(250);
SIM5320.println(F("AT+COPS?"));
delay(250);
SIM5320.println(F("AT+CGSOCKCONT=1,\"IP\",\"web.colombiamovil.com.co\""));
delay(250);
SIM5320.println(F("AT+CNSMOD?")); //MUESTRA EN QUE RED ESTA TRABAJANDO
delay(250);
SIM5320.println(F("AT+CSOCKSETPN=1"));
delay(250);
SIM5320.println(F("AT+CIPMODE=0"));
delay(250);
SIM5320.println(F("AT+CNBP?"));
delay(250);
SIM5320.println(F("AT+NETOPEN"));
delay(8000);
SIM5320.println(F("AT+IPADDR")); //IP
delay(500);
SIM5320.println(F("AT+CGSN")); //IMEI
delay(500);
Can you please say me what is wrong with the code?
Thanks in advances.
