i just made that code and its works. the challenge is i want to get the data from the ubidots and put it on the textView, what should i do and what to do. i need it the whole code in android studio so that i can study every detail. thank you
[SOLVED] I want to get data from the ubidots using this http://ubidots.com/docs/devices/android.html
Hi @GoldenRatio! did you try the answer below? (http://community.ubidots.com/t/getting-data-from-ubidots-using-android-studio/222/2?u=hackmed)
If so, what was the output? where did you find a roadblock? This can help the community understand your case.
Now, once you have the value, modifying a textView in Android sounds like a task you should find in Android tutorials or forums.
Changing the Ubidots Android Example to get data
Original function:
public class ApiUbidots extends AsyncTask<Integer, Void, Void> {
private final String API_KEY = "our_api_key";
private final String VARIABLE_ID = "our_variable_id";
@Override
protected Void doInBackground(Integer... params) {
Variable batteryLevel = apiClient.getVariable(VARIABLE_ID);
batteryLevel.saveValue(params[0]);
return null;
New function:
public class ApiUbidots extends AsyncTask<Integer, Void, Value[]> {
@Override
protected Values[] doInBackground(Integer... params) {
Value[] variableValues = batteryLevel.getValues();
return variableValues;
@Override
// Update your views here
yes i tried it, i only copy paste the code and change the API KEY and VARIABLE ID. I only see on my app is the battery level of the phone. and i send data to cloud using aduino to see the app if is retrieving but nothing change on the app. please help me on how to update views.
A TextView can be updated using the method
setText(CharSequence text)
You can check the documentation of the TextViews in Android Developer site and this is a great tutorial on how to manipulate TextViews.
Android Developers: TextView Reference
Android4Beginners: How to modify textview
Hey @GoldenRatio I’m not an Android or Java expert but I can draft an example using App Inventor (ai2.appinventor.mit.edu), would that help?
Here’s an App Inventor Example Code. The app reads the last value of a variable every second.
Designer View:
where:
- Web1 has the URL: http://things.ubidots.com/api/v1.6/variables/YOUR-VARIABLE-ID/values?page_size=1&token=YOUR-TOKEN
- Clock1 TimerInterval = 1000ms
Blocks View:
Here’s the AIA file for your to upload to your AI2 account GET_Ubidots.aia.zip (3.0 KB)
can you please reupload the aia zip file for mitappinventor
