Any way to display the last update date and time in the metric widget? The default “last value” widget just says “latest value” which isn’t that helpful.
Thanks,
-Brian
Thanks,
-Brian
Hi @bbrandaw
Now you can use {{timestamp}}option, example:
An example of some options that you can use:
{{timestamp | date:‘medium’}}: Oct 28, 2010 10:40:23 PM
{{timestamp | date:‘yyyy-MM-dd HH:mm:ss Z’}}: 2010-10-28 22:40:23 -0500
{{timestamp | date:‘MM/dd/yyyy @ h:mma’}}: 10/28/2010 @ 10:40PM
That looks great, thanks! It’s only working for my last_value widgets, though. I’m using minimum and maximum value widgets as well, and the timestamp isn’t appearing for those.
I’m displaying temperature readings from a variety of Raspberry Pi’s around my property. I’m using the minimum and maximum operations to show the day’s high and low temperatures. Ideally I could see when those temperatures were recorded in the widget.
Appreciate the responsiveness!
Hi @bbrandaw,
In this moment we don’t support this feature and technically can be a really long work, however I will added to the backlog of development.
Gustavo.
That’s fine Gustavo, thanks for taking a look at this for me.
-Brian
