I am trying to send data using Mqtt to Ubidots server (30 day trial).
I folowed the steps suggested in the portal for a simple publish example.
But the dashboard only updates once … and after a few samples MQTT connection fails.
Heres is the serial monitor output:
Eventually reconects, but dashboard never updates again.
I also tried a simple example with HTTP with the same result.
Here is the code …
#include "UbidotsESPMQTT.h"
#define TOKEN "here is my token" // Your Ubidots TOKEN
#define WIFINAME "CLAROMEP2" //Your SSID
#define WIFIPASS "55134488" // Your Wifi Pass
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
client.begin(callback);
if(!client.connected()){
client.reconnect();
float temp = random(0, 9) * 10;
float hum = random(0, 9) * 10;
client.add("temperatura", temp); //Insert your variable Labels and the value to be sent
client.ubidotsPublish("Secadero_1");
client.add("humedad", hum);
Please let me know how to troubleshoot/analyze this issue.
Best Regards,
Patricio Lllovera
