[SOLVED] problem sending JSON object with pubsubclient library
Hello, I am new using the platform, my problem: I need to send text variables, and change them at will, for this I understand that I must use the “context” section, and for this I use a JSON work, but I do not get the message to reach The platform would greatly appreciate your help and patience.
I enclose the code I am using
#include "ArduinoJson.h"
#include <WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>    // incluye libreria para interfaz I2C
#include <RTClib.h>   // incluye libreria para el manejo del modulo RTC
RTC_DS3231 rtc;     // crea objeto del tipo RTC_DS3231
bool alarma = false;   // variable de control con valor verdadero
bool alarma2 =false;   // variable de control con valor verdadero
#define WIFISSID "********************" // Put your WifiSSID here
#define PASSWORD "***************************" // Put your wifi password here
#define TOKEN "***************" // Put your Ubidots' TOKEN
#define MQTT_CLIENT_NAME "Put_your_MQTT_client_name_here" // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
                                           //it should be a random and unique ascii string and different from all other devices
 * Include Libraries
#define VARIABLE_LABEL "a1" // Assing the variable label
#define DEVICE_LABEL "ESP32" // Assig the device label
#define SENSOR 12 // Set the GPIO12 as SENSOR
char mqttBroker[]  = "industrial.api.ubidots.com";
char payload[100];
char topic[150];
char str_sensor[10];
char str_lat[6];
char str_lng[6];
 * Auxiliar Functions
WiFiClient ubidots;
PubSubClient client(ubidots);
  char p[length + 1];
  memcpy(p, payload, length);
  p[length] = NULL;
  String message(p);
  Serial.println(topic);
void reconnect() {
  while (!client.connected()) {
    // Attemp to connect
      Serial.println("Connected");
      Serial.print("Failed, rc=");
      Serial.print(client.state());
 * Main Functions
  // Assign the pin as INPUT
  pinMode(SENSOR, INPUT);
    Serial.print(".");
    delay(500);
  Serial.println("");
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  StaticJsonBuffer<300> JSONBuffer;
  JsonObject& root = JSONBuffer.createObject();
  root["%s value"] = "4000";
  //root["context"] = "gps";
  char json[256];
  root.printTo(json, sizeof(json));
  //JsonObject& parsed = JSONBuffer.parseObject(json);
  //const char * valor = parsed["\"value\""];
  //const char * valor2 = json;
  Serial.print("json =");Serial.println(json);
  root.printTo(Serial);
  sprintf(payload, "{\"%s\":", VARIABLE_LABEL); // Adds the variable label
  float sensor = analogRead(SENSOR);
  float lat = 6.101;
  float lng= -1.293;
  dtostrf(sensor, 4, 2, str_sensor);
  dtostrf(lat, 4, 2, str_lat);
  dtostrf(lng, 4, 2, str_lng);
  //sprintf(payload, "%s {\"value\": 10}}", payload);
  //sprintf(payload, "%s {\"value\": 10", payload, str_sensor); // Adds the value
  //sprintf(payload, "%s, \"context\":{\"lat\": %s, \"lng\": %s}", payload, str_lat, str_lng); // Adds coordinates
  //sprintf(payload, "%s } }", payload); // Closes the dictionary brackets
  client.publish(json,topic);
Hi there, the script below will give you a way to create properly context keys accepted by our REST API, feel free to adapt it to your needs
  // Cloud chars
  char payload[700];
  char topic[150];
  char str_val[6];
  // Values to send
  float temperature = random(0, 50);
  /* 4 is mininum width, 2 is precision; float value is copied onto str_temp*/
  dtostrf(temperature, 4, 2, str_val);
  char* str_status = (char *) malloc(sizeof(char) * 20);
  sprintf(str_status, "");
  if (temperature < 12) {
    sprintf(str_status, "\"cold\"");
    sprintf(str_status, "\"sunny\"");
  sprintf(topic, "%s", ""); // Cleans the topic content
  sprintf(topic, "%s%s", "/v1.6/devices/", "weather-station");
  sprintf(payload, "%s", ""); // Cleans the payload content
  sprintf(payload, "{\"%s\":", "temperature"); // Adds the variable label
  sprintf(payload, "%s {\"value\": %s", payload, str_val); // Adds the value
  sprintf(payload, "%s, \"context\":{\"status\": %s}", payload, str_status); // Adds context
  free(str_status);
You may reference additional examples at our docs.
