when i am publishing value 6.9336972 as
client.add(“stuff”, 6.9336972);
client.ubidotsPublish(“source1”);
value is received as 6.93 to ubidots variable. How can I publish a double value without this issue? I want to publish latitude and longitude to the dashboard map.
Hello @KrishanMadushanka,
Which Ubidots Library are you using?
I am using ubidots-mqtt-esp library.
Dear @KrishanMadushanka,
By the moment the Ubidots Frontend is capable to show just 2 decimals from the variable list view. If you desire visualize more than 2 decimals, you have to create a ** Last value - Metric Widget**. Once the widget is created, press the settings icon an select the number desired of decimals to be displayed.
