[SOLVED] Refresh Need To Show Added Variables
I am new to ubidots and am using it for a school project and i am using the particle photon to communicate send variables to ubidots.
I am using the example code i found ( see link and code below) and it does what i want but after it creates a new variable i need to refresh the page in order for it to show up on the device.
Also if someone could tell me how to update variables instead of making new ones i would be grateful.
Link:
http://help.ubidots.com/connect-your-devices/connect-a-particle-device-to-ubidots
Code:
// This example is to get the last value of variable from the Ubidots API
// This example is to save multiple variables to the Ubidots API with TCP method
 * Include Libraries
#include "Ubidots.h"
 * Define Constants
#define TOKEN "Your_Token"  // Put here your Ubidots TOKEN
Ubidots ubidots(TOKEN);
 * Auxiliar Functions
//Put here your auxiliar functions
 * Main Functions
    //ubidots.setDebug(true); //Uncomment this line for printing debug messages
    float value1 = analogRead(A0);
    float value2 = analogRead(A1);
    float value3 = analogRead(A2);
    ubidots.add("Variable_Name_One", value1);  // Change for your variable name
    ubidots.add("Variable_Name_Two", value2);
    ubidots.add("Variable_Name_Three", value3);
    ubidots.sendAll();
Hello @Operation,
Using the POST code provided in the examples of the Ubidots Particle library, you will be able to create the device and variable desired, plus the automatically update of the variable every time that your the loop run in your device.
