Is there an endpoint for retrieving data between two timestamps?
For e.g.
GET api/v1.6/variables/{variable_id/values/{tstart}/{tend}
I tried this - but it doesn’t work.
Statistics is available for time range, so why is just plain data not available as an endpoint?
ubidots
2
This question was responded through our support channel. Copying the answer here for future reference:
Hi Jai,
Here’s the right command:
http://things.ubidots.com/api/v1.6/variables/5582e589762542477ffac644/values?token=XXXXXXXXXXXXXX&start=1434755858569&end=1437760339623
It turns out our GET values endpoint accepts “start” and “end” as url parameters. On the other hand, a newer endpoint used to compute statistics, accepts “start” and “end” as URL “folder”, as you were trying.
David
@Ubidots
