I find an issue regarding switch widget I setup from dashboard that doesn’t given any response to my serial monitor nodemcu esp8266. Previously I don’t find any problem using ubidots education profile but when I use ubidots STEM profile this issue happen. The code that I use is the same how I use in ubidots education profile as the example given:
* Include Libraries
#include "UbidotsESPMQTT.h"
* Define Constants
#define TOKEN "" // Your Ubidots TOKEN
#define WIFINAME "" //Your SSID
#define WIFIPASS "" // Your Wifi Pass
#define DEVICE_LABEL "switch" //assig device variable
#define VARIABLE_LABEL "button" //assign variable
* Auxiliar Functions
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
* Main Functions
client.ubidotsSetBroker("industrial.api.ubidots.com");
client.begin(callback);
client.ubidotsSubscribe(DEVICE_LABEL,VARIABLE_LABEL); //Insert the dataSource and Variable's Labels
if(!client.connected()){
client.reconnect();
