A user just left this comment in our support box:
I am following this tutorial:
but just got temperature from electric imp. code is exactly as posted but not sure how i can get two sensors data if i only using one ID into electric imp.
please advice
thanks
Alex
              Hi @Alex we suggest these steps:
Define another SPI pin, so that you have two pins for two DHT sensors:
spi  <- hardware.spi257;
spi_2  <- hardware.spi189;
Call the DHT class for every sensor:
dht11 <- DHT11(spi, clkspeed);
dht11_2 <- DHT11(spi_2, clkspeed);
Save both data and send them to the agent:
data <- dht11.read();
data_2 <- dht11_2.read();
server.log(format(“Relative Humidity: %0.1f”,data.rh)+" %");// just to check in the log
server.log(format(“Temperature: %0.1f C”,data.temp));
server.log(format(“Relative Humidity 2: %0.1f”,data_2.rh)+" %");
server.log(format(“Temperature 2: %0.1f C”,data_2.temp));
agent.send(“temp”,data.temp);
agent.send(“temp_2”,data_2.temp);
//agent.send(“rh%”,data.rh); here you would send the relative humidity as well
imp.sleep(1);
All of this is made in the device code. In the Agent code it’s necessary to add a few lines as well:
device.on(“temp”, function(value) {
server.log(“Trying to post to Ubidots the value:”);
server.log(value);
local headers = { “Content-Type”: “application/json”, “X-Auth-Token”: “NBbF3PWPxWc2IaO40aXOKnhIu8tOv92rYN3ibiEc7Jh6GV3KZUUCHtXuNz7Y” }; // Replace with your own token
local url = “http://things.ubidots.com/api/v1.6/variables/53d2beb37625424630223dac/values”; // Replace with the ubidots variable
local string = {“value”: value};
local request = http.post(url, headers, http.jsonencode(string));
local response = request.sendsync();
device.on(“temp_2”, function(value) {
server.log(“Trying to post to Ubi the value:”);
server.log(value);
local url = “http://things.ubidots.com/api/v1.6/variables/53d2beb37625424630223dac/values”; // Replace with the ubidots variable 2
Hope this helps!
