[SOLVED] Ubidots supports telosb sensor or any advanticsys sensors?
  1. Does ubidots supports telo sb sensor for sensing data?
  2. Does ubidots allow us to add new services in it (i.e) i want to add a java file in ubidots ?
  1. The telo sb sensor uses a serial comunication via USB then to send data to Ubidots you need to use a Raspberry pi or a gateway that collects information from sensor TeleSB and send this data to Ubidots. The TeleSB has no connection to internet and this makes it not possible to send information to ubidots.
  2. What do you mean adding a java file?,
Gustavo.
