[SOLVED] UDP Post responses
I am using UDP to POST data to ubidots and it is working fine. If I send two variables successfully I get OK|OK| as a response. What I was wondering is what if the POST was not successful? What should I expect in response? Is this documented somewhere? The only documentation that I have found so far for sending via UDP is http://help.ubidots.com/developer-guides/sendretrieve-data-from-ubidots-over-tcp-or-udp.
-Larry
Hello @larrycook99,
Refering to the UDP protocol definition you will note that the procotol doesn’t guarantee the delivery of the data, also it doesn’t provided a response of the request sent. Internally at Ubidots, we provide a friendly response:
  • OK - Success
  • Fail - Error
But we doesn’t guarantee that you are going to receive the answer in every request.
