I’m trying to connect a Raspberry Pi3 to my STEM account, but have been encountering the following error message each time:
[INFO] Attempting to send data
(404, {u’message’: u’The request was not found.’, u’code’: 404001})
[ERROR] Could not send data after 5 attempts, please check your token credentials and internet connection
[INFO] finished
Here is what I’ve entered, with the token omitted for obvious reasons:
import time
import requests
import math
import random
TOKEN = “XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX” # Put your TOKEN here
DEVICE_LABEL = “Node Gamma” # Put your device label here
VARIABLE_LABEL_1 = “temperature” # Put your first variable label here
VARIABLE_LABEL_2 = “humidity” # Put your second variable label here
VARIABLE_LABEL_3 = “position” # Put your second variable label here
def build_payload(variable_1, variable_2, variable_3):
# Creates two random values for sending data
value_1 = random.randint(-10, 50)
value_2 = random.randint(0, 85)
# Creates a random gps coordinates
lat = random.randrange(34, 36, 1) + \
random.randrange(1, 1000, 1) / 1000.0
lng = random.randrange(-83, -87, -1) + \
payload = {variable_1: value_1,
variable_2: value_2,
variable_3: {"value": 1, "context": {"lat": lat, "lng": lng}}}
return payload
def post_request(payload):
# Creates the headers for the HTTP requests
url = “http://stem.ubidots.com”
url = “{}/api/v1.6/devices/{}”.format(url, DEVICE_LABEL)
headers = {“X-Auth-Token”: TOKEN, “Content-Type”: “application/json”}
# Makes the HTTP requests
status = 400
attempts = 0
while status >= 400 and attempts <= 5:
req = requests.post(url=url, headers=headers, json=payload)
status = req.status_code
attempts += 1
time.sleep(1)
# Processes results
print(req.status_code, req.json())
if status >= 400:
print("[ERROR] Could not send data after 5 attempts, please check \
your token credentials and internet connection")
return False
print("[INFO] request made properly, your device is updated")
return True
def main():
payload = build_payload(
VARIABLE_LABEL_1, VARIABLE_LABEL_2, VARIABLE_LABEL_3)
print("[INFO] Attemping to send data")
print("[INFO] finished")
if name == ‘main’:
while (True):
main()
time.sleep(1)
What am I doing wrong here?
