I am using Nick O’Leary’s Arduino Client for MQTT on the SparkFun Thing Dev (an ESP8266 microcontroller). I have used thee MQTT library on this board successfully in the past with other MQTT servers. But, I am unable to publish data to my datasource’s variables on Ubidots.
I am able to connect to Ubidots’ MQTT server successfully. Here are some code snippets:
char mqtt_server[] = “things.ubidots.com”; // the ubidots.com MQTT server
int mqtt_port = 1883; // the ubidots.com MQTT port
client.setServer(mqtt_server, mqtt_port); // configure the MQTT client with the MQTT server address:port
if (client.connect(“mqtt://things.ubidots.com”, “”, “”))
Serial.println(“connected”);
But when I view my datasource and variables in the dashboard after the microcontroller publishes data, there is no activity / data. The label for my datasource is “incubator”. I have four variables in that datasource with labels: ambienttemp, bottomtemp, toptemp, and heaterstatus.
Here is the code for publishing:
void sendToCloud()
// construct the JSON object
message[“ambienttemp”] = lm35Temperature;
message[“bottomtemp”] = temperature[0];
message[“toptemp”] = temperature[1];
if (heaterOn)
message[“heaterstatus”] = “on”;
else
message[“heaterStatus”] = “off”;
// convert JSON object to string
message.printTo(msg, sizeof(msg));
Serial.print(“Publish message: “);
Serial.println(msg);
client.publish(”/v1.6/devices/incubator”, msg);
I can’t figure out what I am doing wrong. I may be getting a little confused with Ubidots’ terminology. The dashboard is all about “datasources” while a lot of the documentation talks about “devices”. I was unable to create a “device” in the dashboard.
@peejster Could you paste here all of your code, i think that you are forgetting some parts of the code
Okay. Here is the entire sketch:
#include <OneWire.h> // for reading data from DS18B20 sensors
#include <ESP8266WiFi.h> // for WiFi connnectivity
#include <PubSubClient.h> // for MQTT connectivity; documentation at http://pubsubclient.knolleary.net/api.html#PubSubClient1
#include <ArduinoJson.h> // for JSON encoding of MQTT message
const int sensorCount = 2; // define the number of DS18B20 sensors
const int tempPin = 2; // DS18B20 temp sensors are connected to digital pin 2
const int lm35Pin = 0; // LM35 temp sensor is connected to A0
const int heaterPin = 15; // heater switched via digital pin 15
OneWire ds(tempPin); // create an instance of the temp sensors
WiFiClient espClient; // create an instance of the wifi client
PubSubClient client(espClient); // create an ESP8266 compatible client instance of the MQTT client
float temperature[sensorCount]; // store the temp reading from each DS18B20 sensor
float lm35Temperature; // store the temp reaing from the LM35 temp sensor
char ssid[] = "<my_wifi_network>"; // your network SSID (name)
char pass[] = "<my_password>"; // your network password (use for WPA, or use as key for WEP)
char mqtt_server[] = "things.ubidots.com"; // the ubidots.com MQTT server
long lastMsg = 0;
char msg[100];
bool heaterOn = false;
StaticJsonBuffer<100> jsonBuffer;
JsonObject& message = jsonBuffer.createObject();
void setup()
Serial.begin(115200); // initialize the serial monitor
connectWifi(); // establish wifi connection
client.setServer(mqtt_server, mqtt_port); // configure the MQTT client with the MQTT server address and port
pinMode(heaterPin, OUTPUT); // initialize the heater pin
digitalWrite(heaterPin, LOW); // set heater pin to low (off)
void loop()
// make sure you are connected to the wifi network
if (WiFi.status() != WL_CONNECTED)
connectWifi();
// make sure you are connected to the MQTT server
if (!client.connected())
reconnect();
long now = millis();
if (now - lastMsg > 60000) // take temp readings and post to cloud every 60 seconds
lastMsg = now;
// take reading from temperature sensors
getDS18B20Temp();
getLM35Temp();
// check temperature in incubator
if (temperature[0] < 31.0)
// turn on heater
Serial.println("Turning heater on");
digitalWrite(heaterPin, HIGH);
heaterOn = true;
else if (temperature [0] > 33.0)
// turn off heater
Serial.println("Turning heater off");
heaterOn = false;
sendToCloud();
// connect to wifi network
void connectWifi()
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("Connected to wifi");
// record the temperature from all the DS18B20 sensors
void getDS18B20Temp()
byte data[12];
byte addr[sensorCount][8];
// send a reset pulse
ds.reset_search();
// then receive presence pulse from the devices
for (int i = 0; i < sensorCount; i++)
if ( !ds.search(addr[i]))
Serial.println("No devices.");
ds.reset_search();
temperature[i] = -1000;
return;
// get readings from the devices
// verify the device's CRC
if (OneWire::crc8(addr[i], 7) != addr[i][7])
Serial.println("CRC is not valid!");
return;
// check the device type
// Serial.print("Device ");
// Serial.print(i);
if (!((addr[i][0] == 0x10) || (addr[i][0] == 0x28)))
Serial.print(" is not recognized: 0x");
Serial.println(addr[i][0],HEX);
return;
// Initiate a conversion on the temp sensor
ds.reset();
ds.select(addr[i]);
ds.write(0x44,1);
// Wait for the conversion to complete
delay(850);
// Read from the scratchpad
ds.reset();
ds.select(addr[i]);
ds.write(0xBE);
for (int j = 0; j < 9; j++)
data[j] = ds.read();
// Serial.print(data[j], HEX);
// Serial.print(" ");
// Serial.println("");
// calculate temp
temperature[i] = (((data[1] << 8) + data[0] )*0.0625);
Serial.print("DS18B20 sensor ");
Serial.print(i);
Serial.print(": ");
Serial.println(temperature[i]);
return;
void getLM35Temp()
lm35Temperature = analogRead(lm35Pin) / 10.24;
Serial.print("LM35 sensor: ");
Serial.println(lm35Temperature);
void reconnect()
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// Boolean connect(const char* clientId, const char* username, const char* password);
if (client.connect("mqtt://things.ubidots.com", "<my_token>", ""))
Serial.println("connected");
// Once connected, publish an announcement...
// client.publish("/users/peejster/temp/ambient", "0");
// ... and resubscribe
//client.subscribe("inTopic");
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
void sendToCloud()
message["ambienttemp"] = lm35Temperature;
message["bottomtemp"] = temperature[0];
message["toptemp"] = temperature[1];
if (heaterOn)
message["heaterstatus"] = "on";
else
message["heaterStatus"] = "off";
Serial.print("Publish message: ");
client.publish("/v1.6/devices/incubator", msg);
Solved.
I was sending a string instead of a float or integer for the value of my “heaterstatus” variable; the value can only be a float or integer. If I want to send a string, it needs to be a JSON object with metadata for the context key.
Since I just want to track off and on for the heater status, I just used 0 and 1 for the value.
One reason it took me so long to trouble shoot is that the client.connect call would always return true (I added code to what I posted above which printed out the return value from the client.connect call). I wonder why I would get a response of true from the Ubidots API if I was sending invalid type in my JSON message.
Here is the code change to make the above work:
if (heaterOn)
message["heat"] = 1;
else
message["heat"] = 0;
