I have trashed a device from Ubidots and would like to recycle it
The processor {Photon} is operating and should be reporting but trashing has cut the connection
Greetings @SunO, I do not understand your post, what do you mean by ‘recycle’ and ‘trashed’?
I have 30 Photons reporting as devices to Ubidots
For one Photon I have navigated to devices hovered over statusand pressed the trash icon
I now wish to allow this Photon to report back thru Ubidots
Greetings @SunO, if you erased your device from your Particle account, follow their setup guide to add again to your account. Once you have it available again at particle web IDE, upload your customized firmware again.
The photon is has remained running on the Particle account constantly and is operating a valve
I trashed the device in the ubidots devices page and it is no longer visible in ubidots.
I have reloaded the firmware to the Photon but it has not reappeared on ubidots
I have copied the photon ID onto a new device in ubidots but no result
