Hi There
I have a battery widget that shows the batt of a 3V coin cell. Im trying to set the color logic on the widget as follow
on select color logic it is set as follow:
range from 2900 green
range from 2500 red
Full range value in the widget is 2500 to 3100
the widget is green from 3100 to 2900 then turns red from 2900 down to 2500 which is correct. but then it turn green again. I would like to keep it red. I think im misinterpreting the range logic values
Is htere any documentation on this?
I would also like to know how to add “mV” after the reading, is that done in the HTML code or in my variable I send?
thanks so much
