Hi.
I need to connect ubidots through wifimanager. But I can not, when I set the pass and the wifiname connects perfectly but with wifimanager I can not. could you show me an example please thank you so much.
Greetings, please refer to the links below:
http://community.ubidots.com/t/solved-can-i-use-esp8266-using-mqtt-without-connection-manager/664/2
https://www.hackster.io/50441/connect-your-esp8266-to-any-available-wi-fi-network-3d7514
Hope it helps you
