Turn on an LED using Spark Core
Team Ubidots
I am trying to turn on a led using a spark core but it does not work. Here is the code:
// This #include statement was automatically added by the Spark IDE.
// Declaring the variables.
#include "HttpClient/HttpClient.h"
HttpClient http;
#define relay_SWITCH "5535a72b762542455accb953"
#define led_SWITCH "5535a8987625424c69cab006"
#define TOKEN "TOKEN_HERE"
int led_on;
int relay_on;
//necessary part for UBIDOTS
// Headers currently need to be set at init, useful for API keys etc.
http_header_t headers[] = {
      { "Content-Type", "application/json" },
      { "X-Auth-Token" , TOKEN },
    { NULL, NULL } // NOTE: Always terminate headers will NULL
http_request_t request;
http_response_t response;
// initial configuration
    pinMode(D7,OUTPUT);
    pinMode(D6,OUTPUT);
    request.hostname = "things.ubidots.com";
    request.port = 80;
    //Serial.begin(9600);
// main loop= the program
//Better doing a function for this code, but I guess is easier to understand in this way
 response.body = "";
 response.status = 0;
 //request.path = "/api/v1.6/variables/"led_SWITCH"/values?page_size=1";//
 request.path = "/api/v1.6/variables/"led_SWITCH"/values";
 http.get(request, response, headers);
 //led_on = response.body.indexOf(search_on);//Search for value 1.0
 if (led_on == -1) {//red_on default value is -1
     digitalWrite(D7, LOW); //turn off
 else if (-1 < led_on) {
     digitalWrite(D7, HIGH);//turn on
The have error in this line:
I reviewed the samples but I do not understand. Do you have a hello world code for turning on a led using spark core?
Thanks in advance.
José Vuelvas
Hi Jose,
Just tried this code based on yours and it worked!
HttpClient http;
int led_on;
int relay_on;
    pinMode(D7,OUTPUT);
    pinMode(D6,OUTPUT);
    request.port = 80;
 response.body = "";
 led_on = response.body.indexOf("\"value\": 1");
 if (led_on == -1) {
     Serial.println("Led is off");
     Serial.println("Led is on");
See serial output:
HttpClient>.Connecting to: things.ubidots.com:80
HttpClient>.Start of HTTP Request.
GET /api/v1.6/variables/5535a8987625424c69cab006/values?page_size=1 HTTP/1.0
Connection: close
HOST: things.ubidots.com
X-Auth-Token: XXXX
HttpClient>.End of HTTP Request.
HttpClient>.Receiving TCP transaction of 128 bytes.
HTTP/1.1 200 OK
Server: nginx
Date: Sat, 25 Apr 2015 13:13:18 GMT
Connection: close
Vary: Accept-Encoding
Vary: Accept
{“count”: 7, “next”: “http://things.ubidots.com/api/v1.6/variables/5535a8987625424c69cab006/values?page=2&page_size=1”, “previous”: null, “results”: [{“url”: “http://things.ubidots.com/api/v1.6/values/553b923e76254206a96d541d”, “value”: 1.0, “timestamp”: 1429967422077, “context”: {}, “created_at”: “2015-04-25T13:10:22.077”}]}
HttpClient>.End of TCP transaction.
HttpClient>.End of HTTP Response (1306ms).
HttpClient>.Status Code: 200
> Led is on
