if one does not specify an Iot protocol when instancing ubidots (ubidots.h library), does it default to http, tcp ?
I was studying the examples.
In the send with timestamp example we have
In the send with HTTP we get.
Also, is there and advantage to use TCP over HTTP when using send or get
Ubidots ubidots(UBIDOTS_TOKEN, UBI_TCP);
vs
My use case is sending weather sensor data to ubidots hourly, deep sleep between readings.
Sorry for the noob questions.
Greetings @micromet I hope you are doing great.
Regarding the default protocol, the Ubidots class uses TCP protocol by default if not specified in the arguments.
An instantiation like:
Will cause the ubidots object to use TCP protocol by default, as if it had been instantiated like Ubidots ubidots(UBIDOTS_TOKEN, UBI_TCP);
Now, about which protocol is better to use, it highly depends on the hardware that you are using and your requirements as user, however, something I have noted sometimes, is that when using TCP, sending the data is a bit faster than HTTP.
Please reach back to us if you encounter any other doubt.
Best regards
–Juan David
