Hello!
I am using a Node Red Flow to capture wireless IoT Sensor Data from NCD, and sending it to Ubidots.
I have noticed over time that we are getting missed data/messages on Ubidots. Specifically, I can see the data coming in from the sensors (I have reviewed the csv files backups), and yet the data is missing on ubidots.
I suspect it is either a network issue or perhaps I am maxing out on rate limits?
I have added a rate limit node (node-red-ratelimit (node) - Node-RED) to ensure I dont hit any rate limits of 4 /sec, but it hasn’t solved it completely.
Do you have any ideas, perhaps any queue nodes or failure checking, so that if a message is received and attempted to be uploaded to ubidots, but can’t, the system will hold it or retry it?
I am thinking about this (saw this on another post), but not sure if this will work or if there is a better idea? node-red-contrib-msg-queue (node) - Node-RED
Hope this makes sense - let me know if you have any ideas! Thanks in advance! ![]()
