Greetings,
I have followed the tutorial to connect my arduino mega with an esp8266 device and send values to ubidots. Two months ago everything was working properly. I paused my project and resumed it this week and now I can’t receive the values on ubidots. I have checked the connection of my esp8266 which is working fine.
This is my code:
I have omitted my token and username purposely for this post.
* Define Constants
namespace {
bool flow_control = true; // control the flow of the requests
const char * USER_AGENT = ""; // Assgin the user agent
const char * VERSION = "1.0"; // Assign the version
const char * METHOD = "POST"; // Set the method
const char * TOKEN = ""; // Assign your Ubidots TOKEN
const char * DEVICE_LABEL = "ESP"; // Assign the device label
const char * VARIABLE_LABEL = "gas"; // Assign the variable label
char telemetry_unit[100]; // response of the telemetry unit
/* Space to store values to send */
char str_sensor1[10];
//char str_sensor2[10];
* Main Functions
Serial1.begin(115200);
char* command = (char *) malloc(sizeof(char) * 128);
/* Wait for the server response to read the values and built the command */
/* While the flag is true it will take the sensors readings, build the command,
and post the command to Ubidots */
if (flow_control) {
/* Analog reading */
float sensor1 = analogRead(A0);
//float sensor2 = analogRead(A1);
dtostrf(sensor1, 4, 2, str_sensor1);
//dtostrf(sensor2, 4, 2, str_sensor2);
/* Building the logger command */
sprintf(command, "init#");
sprintf(command, "%s%s/%s|%s|%s|", command, USER_AGENT, VERSION, METHOD, TOKEN);
sprintf(command, "%s%s=>", command, DEVICE_LABEL);
sprintf(command, "%s%s:%s", command, VARIABLE_LABEL, str_sensor1);
sprintf(command, "%s|end#final", command);
/* Prints the command sent */
Serial.println(command);// uncomment this line to print the command
/* Sends the command to the telemetry unit */
Serial1.print(command);
/* free memory*/
free(command);
/* Change the status of the flag to false. Once the data is sent, the status
of the flag will change to true again */
flow_control = false;
/* Reading the telemetry unit */
int i = 0;
while (Serial1.available() > 0) {
telemetry_unit[i++] = (char)Serial1.read();
/* Change the status of the flag; allows the next command to be built */
if (flow_control) {
/* Print the server response -> OK */
Serial.write(telemetry_unit);
/* free memory */
memset(telemetry_unit, 0, i);
This is what the serial monitor shows:
(omitted the username and token in here)
init#username/1.0|POkk|ESP=>gas:72.00|end#final
…Oo6ybK58HVVkk|ESP=>gas:72.00|end#final
…init#username/1.0|POST|token|ESP=>gas:72.00|end#final
…init#username1.0|POST|token|ESP=>gas:73.00|end#final
